SIP dailing from Outlook
RayS
Hi
I thought I'd tell you about a small app that allows you to dial out from Outlook (2007 tested here) using a SIP handset (mine's a Grandstream Budget-Tone 100). Oh, and BTW it's free!
The file can be downloaded from -
https://sourceforge.net/project/showfiles.php?group_id=146322
Instructions for the installation are at -
http://www.enum.at/SIP-TAPI.479.0.html
Its as simple as coping the unzipped file into Windows\System32 directory.
Set up is through "control panel/phone and modem options" by adding a new TAPI device.
My setup is as follows -
SIP domain                      = sip2.plus.net
SIP Outbound Proxy          = the IP address of your SIP phone handset
User                                = nnnnnnn
password                          = *******
User's extension                = nnnnnn@sip2.plus.net
If this is your only TAPI device Outlook will pick it up automatically.
Using it is easy, using Outlook contacts - select the contact and click on the phone icon to start the dialling process, lift the handset when it rings and you're there! The call is automatically routed.
Ray
RichSmol
Re: SIP dailing from Outlook
of course, i'd recommend using sip.plus.net as sip2 is being end of lifed at some point.
puddy
Rich
You got their first re sip sip2
puddy
RayS
Thanks to Rich and Puddy for the info. I hadn't updated my old setup.
Ray
