Registration expires after only 25 seconds
MartinDBaker
Hi, I have a 2800VG, and have set the "Expiry Time" for my PlusNet SIP account to be 1 day. However, my SYSLOG shows that the registration is expiring every 25 seconds. This seems far to short and fills the logs up.
How can I change this to a much greater expiry time please?
Cheers
Fixes: 44
Re: Registration expires after only 25 seconds
If you are on the VOIP beta trial then the expiry time is about 25 seconds and apparently that is correct!! There is nothing you can do to change it. I'm not sure about the expiry time on the normal PLusTalk SIP account.
fotobits
I've heard of this and oddly my adapter's Expiration Duration is set to the default of 3,600-secs and correctly re-registers every 30-mins.
Perhaps Gradwell's can't get at my adapter!
Regards
acr
As the owner of a 2800VG you may be interested in this previous thread.
http://community.plus.net/forum/index.php/topic,57898.0.html
