Registration Failure
minimos
I have the broadband phone activated on my account and in the past have used an N95 to make and recieve calls.
A couple of months back I first go a registration failed messgae, but did not have time to investigate, until now.
I have created a new profile on the phone and renetered all the SIP details, but I still get the same message.
Is there a fault on the service?
Thanks in advance
Minimos
[Moderator's note by Thomas (Be3G): moved to a more appropriate forum.]
James
Re: Registration Failure
Hiya,
Are you using "newsip" instead of "sip.plus.net"?
Gradwell made a slight changes which affected all Nokia devices.
itsme
Note to Mods:
Shouldn't this be in 'Broadband Phone' and not 'Home Phone'?
It should indeed - in future, if you see anything like this can I ask please that you use the 'report to moderators' link at the bottom of an offending post. That way we immediately know something's afoot - in this case, it ended up being Jameseh who reported your post to bring the incorrect placement of the thread to our attention. Thanks. Smiley
minimos
Thanks for the replys changing the realm to newsip sorted the problem.
Apologies for posting in the wrong forum, I must have been blind not to have seen the broadband phone area  Shocked
Be3G:
No problem.    Never had occasion to do it before, so will do as you say should I notice something like that again.  Sincere apologies.
No need to apologise. Smiley
