Recommendations for broadband phone hardware
zpeterk
Hi all
Can anyone recommend hardware that will connect existing phones to voip and still keep them connected to the pstn line, ie so you can recieve your pstn calls but dial out on voip
1 REPLY
Fixes: 43
Re: Recommendations for broadband phone hardware
There's some information in this thread http://community.plus.net/forum/index.php/topic,70943.0.html
Check the last post regarding using same phone with landline & voip.
Post back with any queries.
