Re: Google Phone
kamakura
Re: Google Phone
Hello everyone and happy new year to you all.
does anyone own a Grandstream Budgetone 200 ip phone ?. Roll eyes
i have just bought this ip phone last thursday and iam having some problems configuring to work on plusnet voip. Sad
the sip settings are correct as my broadband phone email displayed. Shocked
iam getting a dialtone but cant phone out to any numbers or receive calls either. Cool
there is sufficent funds available in my voip account as well. Embarrassed
if anyone could help me i would greatly appreciate this a lot. Cheesy
cheers kamakura.
Fixes: 116
Re: Re: Google Phone
Hi Kamakura and welcome to the forums..
I split your post out and put it in a more appropriate forum for you Smiley
I don't have a 200 but an older 100 that I have working OK.
What are your your sip server settings and your outbound proxy set to?
they should be sip.plus.net and natproxy.plus.net:5082, your password is also case sensative.
Will Moderate For Thanks
Fixes: 43
Re: Google Phone
There's a screen dump of the BT100 ( looks like the BT200 is similar! ) settings in this thread http://community.plus.net/forum/index.php/topic,57674.msg471302.html#msg471302 if it helps, although it has the old settings for sip server & proxy and you need to replace them with the new ones as posted by Adie.
kamakura
Re: Google Phone
Hello again i have just tried changing the settings and rebooted its not made any difference at all  Roll eyes
iam going to phone the place where i bought my budgetone 200 from tommorrow and see if they can help me. Smiley
its just quite annoying when you buy something and its not working as its supposed to do !. Shocked
i will let you know how i get on and cheers for trying to help me.  Huh
Fixes: 43
Re: Google Phone
@kamakura,
Does you voip control panel ( voip.plus.net ) show you as being online ? that will check whether your BT200 is registering ok.
If you login to your account from the control panel and go to 'account overview' it should show something like this
Broadband Phone 120 2007-11-28 07:58:02 01260 2xxxxxx 8xxxxxx (Ext) online until 2010-01-10 14:01:42
If that shows online then can I suggest you check your voip account using a softphone like SjPhone or X-Lite, if not then it looks like your BT200 is either not configured correctly or is faulty.
puddy
Re: Google Phone
Hi
Here are the settings for Grandstream devices they are for the GXP2000 model but should work with your device
As for dialing out your account my need resetting, my neighbour has got plusnet voip he makes a 4 second call and it then tells him the account has no funds but we know its has.
Account Name : Plusnet Voip
SIP Server: sip.plus.net
Outbound Proxy:natproxy.plus.net:5082
Sip User ID: extension number
Authenticate ID extension number
Authenticate Password voip account password
Name: name (shows on display)
Use DNS SRV =no
User ID is phone number =no
Sip Reg = yes
Unregister On Reboot =no
Register expiration 3600
Local SIP port: 5060
SIP T1 Timeout:1sec
SIP T2 Interval: 4sec
Sip Transport:=UDP
Use RFC3581 Symmetric Routing =no
Nat Traversal (STUN) =no
SUBSCRIBE for MWI:=no
PUBLISH for Presence:=no
Proxy-Require : natproxy.plus.net:5082
SendDTMF: Via RTP (RFC
Early Dial= no
Enable call feature = YES
Session Exp =180
Min-SE =90
Caller req timer =no
Callee req Ref =no
Force timer =no
UAC Spec Ref =omit
UAS Spec Ref =UAC
Force INVITE  =no
Enable 100rel:=no
Account ring tone= you choose
Send Anonymous:= you choose/no
Anonymous Method: =no
Anonymous Call Rej=no
Auto Answer:=NO
Allow Auto Ans byCall:=no
Turn Off Speaker =no
Check SIP User ID: =no
Refer to Use Target:=no
Choice 1:=PCMU
2 TongueCMU
3: G.729A/B
4: G.723.1
5: G.726-32
6: iLBC
7:G.722(wide Band)
8:GSM
SRTP mode:=Disable
eventlist=blank
Special Feature Standard
puddy
kamakura
Re: Google Phone
Hello everyone i have managed to finally get my grandstream budgetone 200 configured.
i have also made a few test calls and everything is working fine now the audio is very clear too.
the only small issues iam sometimes experiencing are when i sometimes try to use the phone iam getting error codes on the lcd.
these error codes are 488 and a busy tone and also occasionally 304.
so what i have been trying is to reboot the grandstream budgetone 200 and leave it for a few minutes this seems to cure the problem.
i really appreciate everyones replies to my question its reassuring to know that there are people who want to help you.
if anyone ever needs any help with their laptop or desktop just message me and i will do what i can to help you.
cheers kamakura.
Fixes: 43
Re: Google Phone
Error code 488 'Not Acceptable Here' is usually down to a codec error. Try disabling any codec's other than G.711a,u and G.729 as they are the only ones supported by the Plusnet(Gradwell) voip system. Code 304 is an odd one but, I believe, can also be codec related...
