Question regarding Call Forwarding and Voicemail
waynemorrell
1) Is it possble to set up call forwarding from the Voip number to another number?
2) Is it possible to change the voicemail PIN ?
Thanks,
Regards,
Wayne
Fixes: 42
Re: Question regarding Call Forwarding and Voicemail
You should be able to do both of those from the voip control panel ( voip.plus.net ).
Login , select Account Overview and then click on the extension number ( highlighted ).
That will give you the details of the account allow changing various things.
Voicemail & Divert/Transfer are in the lower half of the form.
Hope that helps
waynemorrell
Thanks for that.
Regards,
Wayne
