Question about Skype network priority
techguy
Hi
Although I know you'd rather I use gradwell's bb phone I was wondering whether Skype is also treated as VOIP traffic and thus given high network priority?
Re: Question about Skype network priority
All identified VoIP traffic is prioritised highly, including Skype.
B.
techguy
Thanks Barry
I don't think that much of VoIP myself but several friends use skype and I have an account on it so I may as well use it (cheaper than phoning them)
puddy
I do use plusnet and sipgate voip network did you know you can get in to real voip service from free?
Free if you already have a Nokia E65 N82 N95 N95-8GB and N96 mobile phone (not vodaphone supplied)
Upgrade router time look for speedtouch 716 wl wireless (which has 2 voip ports) router from 99p or a Linksys PAP2 adapter from £15
With real voip you dont need to leave your computer on to make and receive calls
Change your home phone for a cordless look at siemens c 450 460 475 dect ip phone models allow you to make normal landline calls and voip calls with the same phone and you can add slave cordless handsets to.
puddy
ps all except the nokia mobile phones you need at least one spare port on your router
