Problem with nokia n73 (Voip)
Antp
hey,
so ive got voip setup on my nokia n73
but i cant make outgoing calls, i have done it on the n95 where you just choose internet call.
but on my n73 i have no option for this but in the sip settings menu it shows th sip as being registered with the server. Huh
Help anyoneHuh?
RichSmol
Re: Problem with nokia n73 (Voip)
If i remember correctly (and if its anything like the N95) you need to make sure that the wireless settings are correct - look for 'always use the available wireless network' or some derivative of that setting. I have a feeling that its set to 'make me choose' which may cause problems.
Antp
No, its over 3g, im using nimbuzz currently and that works fine
but id rather use the proper built in option. And what i dont understand is the fact that  it connects to the server with no problem
