Power supply fault on Grandstream VOIP phones
puddy
When I went in to my computer room a week ago my Grandstream GXP2000 had all its lights on and was trying to re-boot itself time and time again.  I thought its was ready for the bin.
I looked on google and found out it was not the phone but a failing power supply  causing the problem
I used my old car sat-nav power adapter which was the same voltage 5v &1.2amp and the phone worked fine since!
Saved myself over £60
Puddy
1 REPLY
paxy
Re: Power supply fault on Grandstream VOIP phones
Smiley
