Poor call quality when using X-lite 5
Fixes: 8
Is anyone else having issues when using X-lite version 5? Sometimes I notice the sound is a bit choppy.
I know the reason - the Ellanoyas are not picking up the traffic properly and for both incoming and outgoing calls it's being put in to 0x80 (gold).
Is there someone else using this soft phone that could check which queue the traffic is in?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 8
Re: Poor call quality when using X-lite 5
This seems a bit hit and miss (mainly miss).
I've been doing more tests and have ONCE seen a call in the correct 0xA0 queue after restarting X-lite.
Fixes: 41
Is it just X-Lite that's being misclassified or is it voip(sip) in general ?
Fixes: 8
That I don't know. I'd have thought if it was a general problem there would be more complaints.
Plusnet Staff
Plusnet Staff
Fixes: 159
Even in Gold it shouldn't really be choppy. I rarely use my VoIP and haven't got X-Lite so can't really give much info here.
I've asked someone to take a look at the wireshark you've submitted.
 Chris Parr
 Plusnet Staff
Fixes: 8
It was between 20:45 and 21:15 last night that I made the call when I noticed the choppiness. It didn't disrupt the call but I could tell it wasn't as good as usual. I also had a VPN session open at the time over which I was using remote desktop.
prichardson
I've had a quick look through the capture. It is unlikely to do with it, but I am seeing one odd thing. Do you know if there is any reason why there is no incoming audio stream for 7.2 seconds from when you started sending data?
One possible reason is silence suppression, however I would still expect the start of the RTP stream to occur, before the silence starts.
Due to the way silence suppression can work, can you disable this and try again?
Regardless, the priority is certainly wrong and will be looked at.
Fixes: 8
I didn't actually speak over the test call so it possibly only started when I handled the receiver.
I'll look in to silence suppression - does that work the same in both directions?
Edit: The only options I can see in X-lite are under Audio Quality
  • Reduce echos from speakers (AEC) - on
  • Reduce background noise - on
  • Automatic gain control - on
  • Preserve bandwidth during silent periods - off
    I'll try changing the last one.
  • jelv (a.k.a Spoon Whittler)
    prichardson
    Yes,
    It's a negotiated settings, so if the client indicates it does not want it, it will result in the relevant RTP stream to occur.
    As above, not convinced it is related though.
    Fixes: 8
    Quote from: jelv
  • I've just uploaded a new trace with the last option changed.
    prichardson
    Eventually got around to this again.
    Yep, that quickly confirms that it wasn't related, but we never expecting anything different. It does however prevent the 7 seconds without a packet to ensure it wasn't related to a flow that was not setup.
    Incidentally, we have received a signature this morning for the Voicemail issue. As per the info I sent to you already, the proposed fix goes beyond Voicemail so there is a good chance we may be resolving this anyway.
    Not sure how far we will be away getting this in as it needs to undergo normal testing first. I will however ask you to do some testing following this.
    Fixes: 8
    Fixes: 8
    The signature update that went in this morning was supposed to fix VoIP.
    Testing today has shown something very strange. Monitoring X-lite startup and an outgoing call it all started OK (0xA0) but then it looks as if mid call it reverted to 0x80!
    prichardson
    Indeed,
    Per the ticket response, this isn't correct and something else we need to check into. This said, something else is happening here other than it not recognising the traffic.
    On the contrary, it is categorising it as something other than VoIP. We will need to find time to work with you on a call and see exactly which signature it is now hitting.
    Fixes: 8
    What progress is being made with this issue? Earlier today there were a number of total drop outs mid call where it went silent at both ends for a few seconds.
    We still don't know what signature it is hitting and therefore whether the Pro add-on would help.
    Edit: Might a gateway hop help? Currently on lo0-central10.ptn-ag04.plus.net [195.166.128.193]
