PlusNet voip and Asterisk
timsmith
Im hoping someone can help as this is making me tear my hair out now!
Ive got an asterisk box installed at home with a routable IP address. The two sipgate VOIP trunks I have configured work perfectly. I recently took up PlusNet Broadband Phone and cannot get the trunk to work reliably.
Without changing the configuration, sometimes calls go through perfectly (to the "weasels test app") and other times, I get messages on the asterisk console that there is no extension configured.  As my asterisk box is continually on and nothing changes between these test calls, I can only assume that something is different in the SIP packetst that PlusNet are sending.
Im pretty new to Asterisk and SIP so Im struggle to suss this one out and would appreciate any help.
the relevant excerpts from sip.conf and extensions.conf are below. At the moment teh call is supposed to go to a Conference Bridge with meetme. As with weasels, sometimes this works and other times it doesnt.
[general]
register=778XXXX:XXXXXX@sip2.plus.net/778XXXX
defaultexpiry=60
[778XXXX]
type=friend
host=sip2.plus.net
canreinvite=no
nat=no
secret=XXXXXX
username=778XXXX
fromuser=778XXXX
qualify=30000
dtmfmode=inband
allow=ulaw
allow=gsm
allow=alaw
allow=g726
context=incoming_778XXXX
fromdomain=sip2.plus.net
insecure=port,invite
[incoming_778XXXX]
exten => s,1,NoOp()
exten => s,n,Verbose(1|Extension XXXX)
exten => s,n,MeetMe(6000,i,54321)
exten => _778XXXX,1,NoOp()
exten => _778XXXX,n,Verbose(1|Extension XXXX)
exten => _778XXXX,n,MeetMe(6000,i,54321)
Many thanks
Tim
Fixes: 43
Re: PlusNet voip and Asterisk
Not had any experience of Asterix but AFAIK  your domain should really be sip.plus.net ( not sip2 ). sip2 is going to be retired soon although I dont think it is yet..
See if that makes any difference.
timsmith
Thanks for the reply.
sip.plus.net does seem to work better in that all calls do actually get presented properly to Asterisk. However, some calls go to the extension matching my username in the defualt context and others go to the extension matching my username in the correct context specified in the peer configuration.
Now, I can just direct these to the same place, but there must be differences in what plusnet are sending that is causing this.
Can anyone advise?
Tim
Fixes: 43
I'm afraid you've lost me there , I'm familiar with a fair amount of voip kit but unfortunately not Asterix.
However have you checked out this post http://community.plus.net/forum/index.php/topic,60696.0.html and this link http://community.plus.net/forum/index.php/topic,60173.msg491058.html#msg491058 from it.
That last link seems to suggest a different set of allowed codecs from the ones you have , that might be worth a try.
