Philips CD3212S VoIP INTERNET PHONE will it work
Just been given a gift of cash and was loking at moving to voip for calls.
Would this system Philips CD3212S VoIP INTERNET PHONE be suitable for connection to the PN voip service?
http://www.pcworld.co.uk/martprd/store/pcw_page.jsp?BV_SessionID=@@@@0041701925.1211020708@@@@&BV_En...
Many thanks
R
Fixes: 44
Re: Philips CD3212S VoIP INTERNET PHONE will it work
I am pretty sure it wont , its just for use on Skype. Can't find any refrence to it on the Philips site though ...
bone
I looked on their website at this one: VOIP3211S/05 which is the nearest model number to the one you mention and it says not.
puddy
Quote from: podman
would this system Philips CD3212S VoIP INTERNET PHONE be suitable for connection to the PN voip service?
No this will not work and it’s very expensive for Skype phone
Have a look at the siemens range of dual dect VoIP ip phones.  You can make a normal phone by pressing the dial button longer than 5sec
To make a VoIP call just press the dial button and let go straight away.
You can add 5 extra handsets look for Siemens model number gigaset ip phones 450,460,465.  I have the gigaset 460ip phone with 3 hansets and can only use 1 VoIP account. cost on amazon for the siemens gigaset 460ip £74.98 or a twin handset cost £110
Amazon sell extra handsets at £35
You do not have to leave your computer on to make calls just your router
Puddy
