Peered SIP providers [Broadband Calls]
Broadband Phone (VoIP)
Gradwell peering is now provided by a service called X-Connect. The users of the following services can be called for free:
   * AQL (**275)
   * CallUK (**285)
   * DeltaThree/IConnectthere (**333)
   * FWD (**393)
   * Gossiptel (**467)
   * Global Village (**484)
   * Iptel (**47Cool
   * The Internet Phone Co (**847)
   * Pipecall (**365)
   * Sipphone.com (**747)
   * Voipfone (**867)
   * VoIP Talk (**87Cool
The peering for sipgate is different to all the rest.
To dial from Gradwell to Sipgate you need to use the following format:
**77744(Direct dial number)
To dial from Sipgate to Gradwell you need to use the following format:
000472(SIP ID)
There are 2 ways to call a non-PN VoIP user:
1. Dial their full SIP address e.g. sip:1000000@sipgate.co.uk
2. Add the unique provider prefix code. Example: to call 12121 on Gossiptel add **467 (including stars) i.e. **46712121
For friends using these peers who want to call you, Gradwell's SIP prefix is **472. PN VoIP users should be able to call Gradwell SIP IDs without using this prefix.
[Moderator's note by Adie (Adiewoo) modified and removed old service references.]
