PAP2T and Netgear DG834N Setup Issues
gbcambridge
having successfully got SJphone working I thought setting up the PAP2T would be a doddle.
The situation is that the PAP2T registers ... the green  telephone light on the PAP2T is solid. But, there is no dialing tone and numbers cannot be dialed. If I call my VoIP number the phone rings but lifting the phone is not recognized and then it transfers (as it should). I am about running out of ideas here.. I have forwarded the ports on the Netgear device without any effect.  I note some correspondents have simply set up the SIP connection on their PAP2T and it has worked out of the box... makes me very suspicious of what I am doing... perhaps making it too complicated?
Any help or suggestions would be most appreciated.  Software in the PAP2T is version 5.1.6(LS) and in the Netgear it is version V1.02.15
Further to the above information, below I show part of the Info information
        Display Name: 760*****                                                  User ID: 760*****
Hook State: On        Registration State: Online
Last Registration At: 4/8/2010 14:12:20                          Next Registration In: 3568 s
Message Waiting: No                                                          Call Back Active: No
Last Called Number:                                                          Last Caller Number:
Mapped SIP Port:
Call 1 State: Idle        Call 2 State: Idle
Call 1 Tone: None        Call 2 Tone: None
Does this help anyone identify the problem?  It seems that I have successfully connected, but no communication is coming through the phone... no dial tone at all!
Thanks in advance.... in return when (and if) this works I shall publish the complete settings of the PAP2T and DG834N so that others do not need to spend a wasted weekend :-)
gbcambridge
Re: PAP2T and Netgear DG834N Setup Issues
Well .... there was a stunning silence in terms of how to fix my problems.
As it happens, all of the above settings were correct, as were the port forwarding in the router. The problem turned out to be the old telephone from BT that I was using for tests. Once I switched to a modern product  all problems went away  :-)
puddy
        UK Settings for Linksys PAP2 Device
Line Enable:  yes
sip port :5060 try 5062 for line 2
proxy :sip.plus.net                  Register: Yes
Make Call Without Reg: No      Register Expires: 3600
Ans Call Without Reg  :  No
Display Name: sip  id number    User ID: sip id number
Password: sip password          Use Auth ID: Yes
Auth ID: sip id number
Audio Configuration
Preferred Codec:G7LLu            Silence Supp Enable: no
Use Pref Codec Only:No          FAX CED Detect Enable:No
DTMF Tx Method: INFO
Line 1  Advance Settings
Proxy and Registration
Outbound Proxy:natproxy.plus.net:5082
save settings
United Kingdom Regional Settings
Dial tone: 350@-19,440@-22;10(*/0/1+2)
Ring back: 400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
Busy tone: 400@-20;10(.375/.375/1)
Reorder tone: 400@-20;10(*/0/1)
SIT 1 tone: 950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
MWI dial tone: 350@-19,440@-22;10(.75/.75/1+2)
CWT1 cadence: 30(.1/2)
CWT2 cadence: 30(.25/.25,.25/.25,.25/5)
CWT frequency: 400@-10
Ring 1 cadence: 60(.4/.2,.4/2)
Ring 2 cadence (BT Call Sign): 60(1/2)
Ring 3 cadence (BT Ring Back): 60(.25/.25,.25/.25,.25/1.75)
Ring 4 cadence: 60(.4/ .8)
Ring 5 cadence: 60(2/4)
Time Zone: GMT
FXS Port Impedance: 370+620||310nF
Caller ID Method: ETSI FSK With PR(UK)
Daylight Saving Rule: start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1:0:
UK dial plan
this will change problems when dialing number
( *x. | **x. | 0xxx xxx xxx. | 186 xxx xxxx | [1-8]xx | [1-8]xxx | [1-9]xx xxxx | 00 xxxxx x. | 141 0 x. | 1470 0 x. )
If you get this problem
Applied al lthe settings that were listed by Puddy ( many thanks) but couldn't receive incoming calls.
Found the answer on Linksys site. The "Use Outbound Proxy" box  has to be set to Yes
