PAP2 setup (one way audio and if phone wont ring)
puddy
                      Line One Info Basic setup
Line Enable:  yes
sip port :5060
proxy :sip2.plus.net                  Register: Yes
Make Call Without Reg: No      Register Expires: 3600
Ans Call Without Reg  :  No
Display Name: sip  id number    User ID: sip id number
Password: sip password          Use Auth ID: Yes
Auth ID: sip id number
                                  Audio Configuration
Preferred Codec:G7LLu            Silence Supp Enable: no
Use Pref Codec Only:No          FAX CED Detect Enable:No
DTMF Tx Method: INFO
Missed this out last time sorry should solve one way audio and may be needed to make phone ring
Line 1  Advance Settings
Proxy and Registration
Outbound Proxy:nat.plus.net:5082
save settings
puddy
