PAP2 no dial tone HELP
zaheeriqbal
I have entered the settings into my PAP2 and although it registers (blue light on line 2 is on), I get no dial tone and it does not seem to dial a number.
I have entered all the infomation into the pap2 except the sip proxy info nat.plus.net:5082 which I do not know where to enter it and I'm not sure if it is needed:
Anyone with similar issues or know how to fix.
itsme
Re: PAP2 no dial tone HELP
It's needed. You have to select Advance options (switch to Advance view) go to the line you are using for the PN and you will see Proxy and this will be sip2.plus.net. Below this is the Outbound Proxy which is nat.plus.net:5082. Make sure Use Outbound proxy is set to yes.
zaheeriqbal
Thanks, got it working without the above setting, but every few hours, it would unregister. I've entered the outgoing proxy as you have written above so lets see what happens.
Hello not sure if you have this sorted already but I got mine to run using the plusnet settings from here http://www.plus.net/support/hardware/linksys_ATA.pdf
Make sure you also forward the stun and sip ports on your router.
If you haven't already I can also advise cancelling the dhcp server and assigning the pap a static i.p
puddy
Quote from: AverageWhiteBloke
The page you refer to are for the old plusnet voip setting and not the voip beta (gradwell) settings
dont confuse the two
puddy
