PAP2 Problems
piperhols
PAP2 Problems
Hi, Same problem as many people it seems, can't seem to recieve any calls just get "the person at extension...."
Some Screenshots for you:
Any help is appreciated!
Also when will 0845 numbers be ported?
Regards,
Mark
piperhols
Re: PAP2 Problems
Would anyone have any ideas for this please?
P.S Thanks for clearing up my 0845 issues Smiley
puddy
Re: PAP2 Problems
please check your outbound proxy
it should be Outbound Proxy:nat.plus.net:5082
I cannot tell from the photo if it got the : in
puddy
dgp
Re: PAP2 Problems
Hi - Try with User Auth ID set to no.  I have a PAP2 and it does work with this, albeit I get random cut-outs.  Regards
