Oversea charges?
jorvikmik
Oversea charges?
It is most likely me but I cannot find the overseas call charges.
I was looking to see how much to call a landline number in Israel using my voip which I already have.
I was thinking of transfering my bt line rental to plusnet but as the 18185 (2p per minute) service is blocked and plusnet charges are 52ppm to Israel I need to find an alternative to 18185.
I don't often phone Israel but the calls are sometimes for 30 minutes or so.
Fixes: 41
Re: Oversea charges?
You can download the broadband phone tariff(pdf) from the here http://www.plus.net/support/broadband_phone/broadband-phone-tariffs.pdf
Looks like Isreal is 2.5ppm to a landline or 10ppm to a mobile
jorvikmik
Thanks for that - I couldn't find it - Halfway between being a silver surfer and the next stage doesn't help
Mick
glloyd
That list is ridiculous take you for ever to find what your looking for then you have to understand all the codes for various charges, Go to Spigate, it's cheaper and their charges are easier to find.
Fixes: 57
18185 isn't blocked by Plusnet http://community.plus.net/forum/index.php/topic,98608.0.html
Just do a search for 18185 on this forum
You mean Sipgate no wonder you cant find things  Grin
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
glloyd
Yoo now wot I munt. My speeling is no hut. Smiley
