Outlook 2003 dialer
RogerG
Outlook 2003 dialer
I'd like to use Outlook 2003 Dialer to make calls with PlusNet VOIP phone but don't know how to set it up.  Has anyone done this successfully?
Fixes: 8
Re: Outlook 2003 dialer
I don't think you can.
The dialer is for dialling numbers over your land line when you are using on old dialup (56K) modem.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 44
Isn't Outlook 2003 TAPI compliant ? If so this http://www.ipcom.at/en/telephony/siptapi/ looks like it could possibly work. I would guess it's not going to be simple though...
RogerG
Thanks for that.  I'll give the ipcom link a try and report back.
