Outgoing calls on Nokia E65 & N95 terminated
puddy
Just when I thought I had got my nokia phones setup I tried making VOIP outbound calls, but within 3 minutes I get cut off.
It does the same on both phone!!!
Puddy
prichardson
Re: Outgoing calls on Nokia E65 & N95 terminated
What values have you specified in the username fields under the sections "proxy server" and "registrar server"?
puddy
here goes
Profile Name: Gradwell
Service Profile: IETF
Default Access Point: <my wireless AP name>
Public User name: sip:<sipnumber>@sip2.plus.net
Use compression: No
Registration: Always on
Use Security: No
Proxy Server
Proxy Server Address: sip:nat.plus.net
Realm: sip2.plus.net
username: <your sip number>
password: <your sip password as set on beta website>
Allow loose routing: Yes
Transport Type: UDP
Port: 5082
Registrar Server
Regsitrar server address: sip:sip2.plus.net
Username: <your sip user id>
Password: <your sip password>
Transport Type: UDP
Port: 5060
any error in their that causing this?
Puddy
account = jillweekes
prichardson
I encountered problems with my E65, though not the same as your when using the format you have.
That is exactly why I asked for the two values I did Cheesy
Try altering the username under Proxy and Registration server sections, to use the format sip:<sipnumber>@sip2.plus.net as is within the main config screen for the profile, under public user name.
puddy
I changed them as requested let’s hope it works thanks for the tip
I also managed to debrand both my nokia phones.  With the de-branding software you get all the software i.e. internet/VoIP  that vodaphone and orange  take out, and the rubbish they put in so you are left with generic nokia phone
it takes about 20 minute to do.
You change the product code then update the firmware on the nokia site
puddy
prichardson
My E65 is from Three. It has the Three firmware on it and that does not restrict anything that I am aware of (or rather, anything I am concerned about so far).
My only bugbear is that the Three theme for the phone crashes it. Hey ho, good job it is rubbish and I am using a different one.
puddy
you need to do an update of firmware then change the product code to 0534841 then run the nokia update firmware again and hey presto its a genric nokia
Its useful if your on orange or vodaphone contract because they delete voip calls software doing the updates above will put it back in again  Cheesy
is you 3 phone sim locked? i found mine  was fully unlocked Cheesy
puddy
sourceit
I changed the settings and now my N82 works again.  What is it with PN/Gradwell changing the settings all the time?  Are they trying to keep us on our toes or something?  Undecided
Ben
puddy
Ben
did you remember to change the internet call baring to off?
tools > settings > phone>  call barring >  internet call barring> anonymous call barring > switch off
your nokia mobile will now ring if number is withheld
Puddy
sourceit
Yeah, left that off after discovering it.  Just the changes that Gradwell/PlusNet make aren't being relayed to the end users or trialists.  Some transparency would be helpful and then maybe we could comment more on the service then bitchin about setiings all the time.
Ben
puddy
Quote from: Source
Ben
I was only trying to help
puddy
sourceit
Sorry I didn't mean it like that.  I meant that if we didn't have to moan all the time about settings that PN/Gradwell change without telling us and then us having to work the settings out, we would be more able to comment on the service.  Moan was meant for PN/Gradwell.
