Nokia N82 and Plusnet
badbetty
Hello readers
I have a Nokia N82. I cannot get it to register with Plusnet for internet/voip calling.
It works fine with Sipgate.
I have tried every combination of settings (i reckon anyway) and checked out the suggestions for other similar phones on this forum.
Nothing has worked so far.
I have been able to connect a softphone on a laptop to plusnet ok (thanks to a forum member on here); also working to sipgate.    I replicated the sipgate settings onto the N82 and it worked.  So, I presumed that replicating the plusnet settings would result in the same thing....a connection.
Anyway, if anyone has any useful information or settings suggestions, please respond.
Thank you.
Fixes: 44
Re: Nokia N82 and Plusnet
Its probably the 'realm'. Most SIP clients dont bother to check authorisation against the realm but the Nokia ( certainly the N95 client ) does.
You need newsip in the realm field.
puddy
Hi
Bob placed this in the library its for the Nokia N95 but should be simlar to the nokia N82
You need voip app version 2.3 and firmware version  10.0.046 and download voip app if you have not all ready done it see below
http://www.forum.nokia.com/info/sw.nokia.com/id/d476061e-90ca-42e9-b3ea-1a852f3808ec/SIP_VoIP_Settin...
http://community.plus.net/library/tools/nokia-n95-broadband-phone-setup-guide/
I have had no luck at all getting any of my phones to work with sipgate could you please pm the settings for me?
Kind regards
Puddy
