Nokia N79 sip settings
zpeterk
I have just set up my Nokia N79 with the following settings from Puddy and all  working in and out in 5 mins, thanks very much. Smiley Smiley
Profile name Plusnet
Service profile: IETF
Default access point: Your router connection
Public user name: sip:your ext number@sip.plus.net  eg sip:6938087@sip.plus.net
Use compression: No
Registration: Always on
Use security No
Next, select 'Proxy Server' and enter the following settings...
Proxy server address: sip:natproxy.plus.net
Realm: newsip
User name: your ext number only
Password: your password
Allow loose routing: Yes
Transport type: UDP
Port: 5082
Now press 'Back', select 'Registrar server' and enter the following settings...
Registrar server address: sip:sip.plus.net
Realm: newsip
User name: Extension Number only
Password: Your password
Transport type: UDP
Port: 5060
1 REPLY
puddy
Re: Nokia N79 sip settings
Glad it worked out okay
Puddy
