Nokia 6300i XML
ericthepig
Nokia 6300i XML
I'm trying to set my Nokia 6300i up to use VOIP. The problem is a provider can normally only be added via a wizard on the phone which only offers Sipgate or Gizmo5.
The other method is to send an XML file containing the VOIP settings to the phone. I have succeeded in adding a Voipcheap account this way, but I can't get it to work for PlusNet.
Has anyone else tried and had any luck with this?
Regards,
Neil
RichSmol
Re: Nokia 6300i XML
Im interested in this - lets have a look at the XML and im sure we can work it out. Maybe one of our developers can help out too if its the required syntax which is the issue here...
ericthepig
Re: Nokia 6300i XML
Thanks.
I'm at work now, so I don't have the XML I used, but below is the example Nokia provide.
I can post the one I used later, if needed.
<wap-provisioningdoc version="1.1">
<!-- XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
<characteristic type="BOOTSTRAP">
<parm name="NAME" value="Example VoIP settings"/>
</characteristic>
<!-- Nokia S40 v72 VoIP settings, w9013
<!-- Settings are described in detail in the Nokia Series 40 VoIP v72 Configuration Tutorial.
<!-- Parameters that are not defined by default have been put in comments in this example.
<characteristic type="APPLICATION">
<parm name="APPID" value="w9013"/>
<parm name="PROVIDER-ID" value="Example provider"/>
<parm name="TO-NAPID" value="Open_VoIP_WLAN_settings"/>
<parm name="TO-NAPID" value="WPA_VoIP_WLAN_settings"/>
<parm name="TO-NAPID" value="WEP_VoIP_WLAN_settings"/>
<parm name="TO-NAPID" value="INTERNET"/>
<parm name="TO-APPREF" value="VoIP_SIP_settings"/>
<parm name="SMPORT" value="16384"/>
<parm name="EMPORT" value="32766"/>
<parm name="MEDIAQOS" value="46"/>
<!-- <parm name="NODTMFOOB"/> not defined by default
<parm name="SECURECALLPREF" value="0"/>
<parm name="RTCP" value="0"/>
<!-- <parm name="G726RFCPAYLOADFORMAT"/> not defined by default
<parm name="MOMAXALERT" value="45"/>
<parm name="MTMAXALERT" value="30"/>
<!-- AMR NB
<characteristic type="CODEC">
<parm name="MEDIASUBTYPE" value="0"/>
<parm name="PRIORITYINDEX" value="0"/>
<parm name="OCTET-ALIGN"/>
<!-- <parm name="PTIME" value="20"/> not defined by default
<parm name="VAD"/>
</characteristic>
<!-- G.729 with default values
<parm name="MEDIASUBTYPE" value="10"/>
<parm name="PRIORITYINDEX" value="1"/>
<!-- <parm name="PTIME" value="10"/> not defined by default
<parm name="ANNEXB"/>
</characteristic>
<!-- G711 a-law with default values
<parm name="MEDIASUBTYPE" value="3"/>
<parm name="PRIORITYINDEX" value="2"/>
<parm name="VAD"/>
</characteristic>
<!-- G711 u-law with default values
<parm name="MEDIASUBTYPE" value="4"/>
<parm name="PRIORITYINDEX" value="3"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-40 with default values
<parm name="MEDIASUBTYPE" value="5"/>
<parm name="PRIORITYINDEX" value="4"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-32 with default values
<parm name="MEDIASUBTYPE" value="6"/>
<parm name="PRIORITYINDEX" value="5"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-24 with default values
<parm name="MEDIASUBTYPE" value="7"/>
<parm name="PRIORITYINDEX" value="6"/>
<parm name="VAD"/>
</characteristic>
<!-- G.726-16 with default values
<parm name="MEDIASUBTYPE" value="8"/>
<parm name="PRIORITYINDEX" value="7"/>
<parm name="VAD"/>
</characteristic>
<!-- CN Comfort noise with default values
<parm name="MEDIASUBTYPE" value="9"/>
<parm name="PRIORITYINDEX" value="8"/>
</characteristic>
<!-- IP Voice mail
<characteristic type="VOIPURIS">
<!-- Link to SIP settings
<parm name="IPVOICEMAILBOXURI" value="robert@ipvoicemailbox.example.com"/>
</characteristic>
</characteristic>
<!-- NAT/FW settings, w902E
<parm name="APPID" value="w902E"/>
<parm name="NAME" value="NAT/FW Traversal settings"/>
<characteristic type="NW">
<parm name="APPREF" value="Example_NAT_FW_settings"/>
<parm name="DOMAIN" value="example.com"/>
<parm name="STUNSRVADDR" value="stunserver.domain.com"/>
<parm name="STUNSRVPORT" value="3478"/>
<parm name="NATREFRESHTCP" value="30"/>
<parm name="NATREFRESHUDP" value="20"/>
</characteristic>
<characteristic type="NATIAP">
<parm name="REFRESHTCP" value="1200"/>
<parm name="REFRESHUDP" value="28"/>
<parm name="STUNRETRANSMIT" value="250"/>
</characteristic>
</characteristic>
<!-- SIP settings, w9010
<parm name="APPID" value="w9010"/>
<parm name="APPREF" value="VoIP_SIP_settings"/>
<parm name="PTYPE" value="IETF"/>
<parm name="PUID" value="sip:robert@example.com"/>
<parm name="APROTOCOL" value="UDP"/>
<!-- Outbound settings
<characteristic type="APPADDR">
<parm name="LR"/>
<parm name="ADDR" value="outbound.example.com"/>
<characteristic type="PORT">
<parm name="PORTNBR" value="5060"/>
</characteristic>
</characteristic>
<!-- Outbound credentials
<characteristic type="APPAUTH">
<parm name="AAUTHNAME" value="robert"/>
<parm name="AAUTHSECRET" value="ja7Gf84r"/>
<parm name="AAUTHDATA" value=""/>
<parm name="AAUTHTYPE" value="HTTP-DIGEST"/>
</characteristic>
<!-- Registrar location and credentials
<characteristic type="RESOURCE">
<parm name="URI" value="registrar.example.com"/>
</characteristic>
</characteristic>
<!-- IAP WLAN settings (Open)
<characteristic type="NAPDEF">
<parm name="NAME" value="Open_WLAN"/>
<parm name="NAPID" value="Open_VoIP_WLAN_settings"/>
<parm name="BEARER" value="WLAN"/>
<characteristic type="WLAN">
<parm name="PRI-SSID" value="examplessid"/>
<parm name="NETMODE" value="INFRA"/>
</characteristic>
</characteristic>
<!--  IAP WLAN Settings (WPA)
<parm name="NAME" value="WPA_WLAN"/>
<parm name="NAPID" value="WPA_VoIP_WLAN_settings"/>
<parm name="SECMODE" value="WPA-PRESHARED-KEY"/>
<parm name="WPA-PRES-KEY-ASC" value="examplesecret"/>
<!-- parm name="WPA-PRES-KEY-HEX" value="96b2a554d1a1277e7a012627ffddc0ceb43f89f32efba8406c0d4aede4638fd7"/> not defined by default
</characteristic>
</characteristic>
<!--  IAP WLAN Settings (WEP)
<parm name="NAME" value="WEP_WLAN"/>
<parm name="NAPID" value="WEP_VoIP_WLAN_settings"/>
<parm name="SECMODE" value="WEP"/>
<parm name="WEPAUTHMODE" value="OPEN"/>
<parm name="WEPKEYIND" value="0"/>
<characteristic type="WEPKEY">
<parm name="LENGTH" value="128"/>
<parm name="INDEX" value="0"/>
<parm name="DATA" value="examplesecret"/>
</characteristic>
</characteristic>
</characteristic>
</wap-provisioningdoc>
RichSmol
Re: Nokia 6300i XML
For NAT settings
-not sure whether you'll need a stun server - get the feeling this device might need one. I've added the details - you can remove if it doesnt work
<parm name="DOMAIN" value="natproxy.plus.net"/>
<parm name="STUNSRVADDR" value="stun.gradwell.net"/>
<parm name="NATREFRESHTCP" value="5082"/>
<parm name="NATREFRESHUDP" value="5082"/>
</characteristic>
</characteristic>
</characteristic>
Replace "your extension" and "your password" with your account details...
<parm name="PUID" value="sip:sip.plus.net"/>
<parm name="LR"/>
<parm name="ADDR" value="sip.plus.net"/>
</characteristic>
</characteristic>
<parm name="AAUTHNAME" value="your extension"/>
<parm name="AAUTHSECRET" value="your password"/>
</characteristic>
<parm name="URI" value="sip.plus.net"/>
</characteristic>
</characteristic>
All the other stuff is related to your wireless access to your chosen network - which looks like you can only configure it through a wireless router. Havent got a clue about those parameters but you'd like to think that the default settings were the same for any phone.
ericthepig
Re: Nokia 6300i XML
Thanks for that, I tried it and I'm getting "Error 403 - Connection rejected by plusnet".
However, I just downloaded and installed SJphone on my PC and I can't connect with that either. Maybe it's a problem with the account, so I've raised a ticket...
itsme
Re: Nokia 6300i XML
Below is my xml setting that I have been using for the last 4 months on the 6300i with no problems. Was going to play around with it for the voicemail but have not got around to it. I assume that you brought the phone from Sipgate as I believe it still not available in the UK?
<?xml version="1.0" ?>
  <!DOCTYPE wap-provisioningdoc (View Source for full doctype...)>
- <wap-provisioningdoc version="1.1">
- <!--  XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
- <characteristic type="BOOTSTRAP">
  <parm name="NAME" value="VOIP-S40-Default" />
  </characteristic>
- <!--  Nokia S40 v72 VoIP settings, w9013
- <characteristic type="APPLICATION">
  <parm name="APPID" value="w9013" />
  <parm name="PROVIDER-ID" value="Plus" />
  <parm name="NAME" value="Plus" />
  <parm name="TO-NAPID" value="VoIP_WLAN_settings" />
  <parm name="TO-NAPID" value="INTERNET" />
  <parm name="TO-APPREF" value="VoIP_SIP_settings" />
  <parm name="SMPORT" value="16384" />
  <parm name="EMPORT" value="32766" />
  <parm name="MEDIAQOS" value="46" />
  <parm name="SECURECALLPREF" value="0" />
  <parm name="RTCP" value="0" />
  <parm name="MOMAXALERT" value="45" />
  <parm name="MTMAXALERT" value="30" />
- <!--  AMR NB
- <characteristic type="CODEC">
  <parm name="MEDIASUBTYPE" value="0" />
  <parm name="PRIORITYINDEX" value="0" />
  <parm name="OCTET-ALIGN" />
  <parm name="VAD" />
  </characteristic>
- <!--  G.729 with default values
  <parm name="MEDIASUBTYPE" value="10" />
  <parm name="PRIORITYINDEX" value="1" />
  <parm name="ANNEXB" />
  </characteristic>
- <!--  G711 a-law with default values
  <parm name="MEDIASUBTYPE" value="3" />
  <parm name="PRIORITYINDEX" value="2" />
  <parm name="VAD" />
  </characteristic>
- <!--  G711 u-law with default values
  <parm name="MEDIASUBTYPE" value="4" />
  <parm name="PRIORITYINDEX" value="3" />
  <parm name="VAD" />
  </characteristic>
- <!--  G.726-40 with default values
  <parm name="MEDIASUBTYPE" value="5" />
  <parm name="PRIORITYINDEX" value="4" />
  <parm name="VAD" />
  </characteristic>
- <!--  G.726-32 with default values
  <parm name="MEDIASUBTYPE" value="6" />
  <parm name="PRIORITYINDEX" value="5" />
  <parm name="VAD" />
  </characteristic>
- <!--  G.726-24 with default values
  <parm name="MEDIASUBTYPE" value="7" />
  <parm name="PRIORITYINDEX" value="6" />
  <parm name="VAD" />
  </characteristic>
- <!--  G.726-16 with default values
  <parm name="MEDIASUBTYPE" value="8" />
  <parm name="PRIORITYINDEX" value="7" />
  <parm name="VAD" />
  </characteristic>
- <!--  CN Comfort noise with default values
  <parm name="MEDIASUBTYPE" value="9" />
  <parm name="PRIORITYINDEX" value="8" />
  </characteristic>
- <!--  IP Voice mail
- <characteristic type="VOIPURIS">
- <!--  Link to SIP settings
  <parm name="IPVOICEMAILBOXURI" value="robert@ipvoicemailbox.example.com" />
  </characteristic>
  </characteristic>
- <!--  NAT/FW settings, w902E
  <parm name="APPID" value="w902E" />
  <parm name="NAME" value="NAT/FW Traversal settings" />
- <characteristic type="NW">
  <parm name="APPREF" value="Example_NAT_FW_settings" />
  <parm name="DOMAIN" value="sip.plus.net" />
  <parm name="STUNSRVADDR" value="0.0.0.0" />
  <parm name="STUNSRVPORT" value="3478" />
  <parm name="NATREFRESHTCP" value="30" />
  <parm name="NATREFRESHUDP" value="20" />
  </characteristic>
- <characteristic type="NATIAP">
  <parm name="REFRESHTCP" value="1200" />
  <parm name="REFRESHUDP" value="28" />
  <parm name="STUNRETRANSMIT" value="250" />
  </characteristic>
  </characteristic>
- <!--  SIP settings, w9010
  <parm name="APPID" value="w9010" />
  <parm name="APPREF" value="VoIP_SIP_settings" />
  <parm name="PTYPE" value="IETF" />
  <parm name="PUID" value="sip:xxxxxxx@sip.plus.net" />
  <parm name="APROTOCOL" value="UDP" />
- <!--  Outbound settings
- <characteristic type="APPADDR">
  <parm name="LR" />
  <parm name="ADDR" value="natproxy.plus.net" />
- <characteristic type="PORT">
  <parm name="PORTNBR" value="5082" />
  </characteristic>
  </characteristic>
- <!--  Outbound credentials
- <characteristic type="APPAUTH">
  <parm name="AAUTHNAME" value="xxxxxxx" />
  <parm name="AAUTHSECRET" value="xxxxxxxx]" />
  <parm name="AAUTHDATA" value="sip.plus.net" />
  <parm name="AAUTHTYPE" value="HTTP-DIGEST" />
  </characteristic>
- <!--  Registrar location and credentials
- <characteristic type="RESOURCE">
  <parm name="URI" value="sip.plus.net" />
  <parm name="AAUTHNAME" value="7xxxxxx" />
  <parm name="AAUTHSECRET" value="xxxxxxxx" />
  </characteristic>
  </characteristic>
- <!--  IAP WLAN settings
- <characteristic type="NAPDEF">
  <parm name="NAME" value="WLAN" />
  <parm name="NAPID" value="VoIP_WLAN_settings" />
  <parm name="PROVIDER-ID" value="Example provider" />
  <parm name="BEARER" value="WLAN" />
- <characteristic type="WLAN">
  <parm name="PRI-SSID" value="examplessid" />
  <parm name="NETMODE" value="INFRA" />
  </characteristic>
  </characteristic>
ericthepig
Re: Nokia 6300i XML
Thanks Robert,
I'm beginning to think maybe I had the settings right in the first place and there's a problem with the account.
Yes, I got it from Sipgate, I assume, for obvious reasons, the UK networks don't want to sell it.
RichSmol
Re: Nokia 6300i XML
Neil - i've just reset your password and just about to do some testing on your account....will be back with you shortly. The new password is in your mailbox!
RichSmol
Re: Nokia 6300i XML
Seems to of done the trick - I hadnt tested the account before so cant really verify whether it worked previously but it works now and i successfully made a test call to my own phone.
cheers
Rich
ericthepig
Re: Nokia 6300i XML
Thanks Rich,
But it will have to wait until I get home now.
Also, I just got a reminder that I'm running low on credit. I've never had one of those before, so maybe that implies something started working....?
I'll post back when I've tried it.
Neil
ericthepig
Re: Nokia 6300i XML
However.
I now see on the broadband phone control panel, the status is "expired at 2009-03-13 09:16:28"
What does that mean?
RichSmol
Re: Nokia 6300i XML
It means your platform session probably expired when the password change went through. The expiry time is only a display function - its not 100% reliable at the moment as it doesnt update in real time so can be rather confusing. We've had to do quite a bit of work to get it right but clearly its not 100% reliable yet...the expiry date / time doesnt have any impact on your accounts ability to register against the platform.
ericthepig
Re: Nokia 6300i XML
Still no joy, I get:
"Service unavailable"
"Server is not responding"
Then, if I try to dial a number, I get:
"Waiting for proxy registration"
Then the account and password prompt (repeatedly)
Neil
ericthepig
Re: Nokia 6300i XML
woo-hoo! I finally got it to dial out by setting the Proxy (URI) value to "sip:sip2.plus.net:5060", as it says on my 'broadband phone control panel.
Maybe the 'SJPhone setup guide for Windows' needs updating.
Now I need to try it with my Nokia...
itsme
Re: Nokia 6300i XML
There is a problem with the control panel reporting sip2.plus.net. It's a long story but at one time there was 2 systems, sip.plus.net and sip2.plus.net. The former was used by PN VoIP system the latter by the current system supplied by Gradwell. When all user were moved over to Gradwell the DNS enters for sip.plus.net where changed to point at the same address as sip2.plus.net. The normal advice is to use sip.plus.net as the sip2.plus.net could be removed.
I have never used SJphone but looking at the instructions I believe it is wrong. The Use Outbound Proxy should be sip.plus.net:5060 and the Use seperate outbound proxy for NAT should be ticked and the NAT proxy should be natproxy.plus.net:5082. As I said I have not used sjphone so hopefully others will confirm the settings.
