No voice on NCH Express Talk 3.10 softphone
JimboS
Hi
I hope someone can help. I have installed Express Talk 3.10 on my plusnet voip. I can make calls and get connected but the other side cannot hear any voice but they can hear DTMF tones if I press numbers. When connecting to an answerphone this too does not detect any voice and simply hangsup but does respond to DTMF commands. I can hear voice from the remote party. (same settings seem to work ok with SJPhone but I need Express Talk)
settings: Proxy: sip2.plus.net:5060  (also tried sip.plus.net:5060)
outbound server:  natproxy.plus.net:5082  (also tried nat.plus.net:5082)
any pointers would be appreciated.  Embarrassed
Fixes: 42
Re: No voice on NCH Express Talk 3.10 softphone
I've got no answers I'm afraid BUT you're not the only one with the problem.
I've been away on business for a few days and made some voip calls using the hotel Wifi.
I had a similar problem to you with Express Talk , sometimes SIP to SIP calls would work Ok but
never got a PSTN call to have outgoing voice.
As you say SjPhone works fine, it seems to be an Express Talk issue.
When I get a moment I'll check through the Express Talk settings.
Ahh , just thought , in my case I'm pretty sure the only time it worked was the first call after starting Express Talk...
mdempers
Hi Guys.
Just to let you know I'm having the same problem. I'm using Express talk 3.10. I have one of my lines in Express Talk configured as my Plusnet VOIP and for another line in Express Talk I have it configured with another provider. For the the other provider I have no problems. For Plusnet line if I recieve a call it all works fine, if I however make a call out on my Plusnet configured line, the other party cannot hear me. Logic tells me ...well I'll let you make your own decision.
Regards
Maurice
