No noise on Outgoing Calls using Linksys PAP2
NickatTSA
Hi, first post here so be kind to me  Undecided  Wink.
Having exactly the same problem as described a few threads below. Since the upgrade we have been unable to have sound when making outgoing calls; we have also been told that the recipient can hear us fine.
We are using a linksysPAP2 router and have I cannot see anything wrong with our settings so I'm confused at how to proceed.
Any guidance would be gratefully received.
Regards
Nick
NickatTSA
Re: No noise on Outgoing Calls using Linksys PAP2
Hello again,
Just to let everyone know that the problem has been sorted - found a post with search that answered everything Smiley
Many thanks
Nick
RichSmol
Brilliant - glad to hear the forums have helped you out. Just to confirm - what was it that you needed to change to solve your problem?
