New user but have no active network interface
nortonhall
Hi
I have registered and downloaded the SJ Phone software but cannot do anything. as have no active network interface?
Can anyone suggest a solution. i have not yet installed a handset as i want to test the system with laptop sound and recorder.
Cheers
Ian
Fixes: 111
Re: New user but have no active network interface
There's something here http://blog.mathiashabluetzel.ch/2012/11/04/sjphone-no-active-network-interface/
How many network interfaces do you have? (wireless / ethernet / vm;s??)
Will Moderate For Thanks
nortonhall
Hello
I looked at your link, this led me to disable my wired ethernet and bluetooth connections.
There was a change in status; now it says i have firewall/nat issues.
I looked at allowed programmes and the software is in the list but still no joy.
Fixes: 111
ok, can you post a screen shot of your settings?
small steps but it's an improvement Smiley
RPMozley
If you're using a windoze machine you'd be better off using 3CXPhone.
And for Mac OS X you should use x-lite (current version is 5).
Note: X-lite 4 on Mac won't even run at all. It bizarrely says that the program has expired, even though it's a free program! Huh
nortonhall
Hi
I have attached a screenshot of the error message in a pdf.
I will also look at the alternative software.
Cheers for all your help so far
Ian
RPMozley
There are setup guides available for 3CXPhone and x-lite (version 4 is listed but is pretty much the same setup as version 5) on the Gradwell support site.
All you need to change is where ".gradwell.com" appears and replace it with ".plus.net".
