New Nokia Phone settings E65 N82 N95 N95-8GB
puddy
This works on all the nokia phone above but I am not sure what you need to change for the Nokia 6300i
Profile name Plusnet
Service profile: IETF
Default access point: Your router connection
Public user name: sip:1234567@sip.plus.net
Use compression: No
Registration: Always on
Use security No
Next, select 'Proxy Server' and enter the following settings...
Proxy server address: sip:natproxy.plus.net
Realm: newsip
User name: 1234567
Password: your password
Allow loose routing: Yes
Transport type: UDP
Port: 5082
Now press 'Back', select 'Registrar server' and enter the following settings...
Registrar server address: sip:sip.plus.net
Realm: nesip
User name: 1234567
Password: Your password
Transport type: UDP
Port: 5060
Puddy
ps not sure if we need to change the settings i.e newsip to other phones like the siemens gigaset and Grandstream products
could we please have answer on this from Plusnet please
James
Re: New Nokia Phone settings E65 N82 N95 N95-8GB
As per my other 2-3 responses in the other thread, you should use "newsip".
It only appears to be affecting Nokia devices.
Daniel mentioned that you had called/mailed.
Fixes: 57
jim:post Locked in favour of http://community.plus.net/forum/index.php/topic,77601.32.html to keep everything together ][/color]
