New Nat Proxy Trial
petergradwell
New Nat Proxy Trial
As the Broadband phone service continues to expand, we need to replace the NAT proxy solution we have. This is the server known as "nat.plus.net" which you have in your phone configs. The NAT proxy does various bits of jiggery-pokery to make VoIP work through firewalls, ADSL routers, etc.
We are therefore running a test of our new NAT proxy service, and if you like testing things then we'd welcome your feedback.
The new nat proxy setting is (replaces nat.plus.net:5082) in your config.
natproxy.plus.net:5082
Please let me know how it goes in this forum thread. You shouldn't really see any difference!
cheers
peter
RichSmol
Re: New Nat Proxy Trial
I will update my desk phone right away!
RichSmol
I've changed the settings on my Flexor 500 and it now says I have an 'invalid username'. Suggestions?
cheers
Rich
FelixBellaby
When using SJPhone, I get "403 Fobidden - no OBP" responses to all SIP requests directed at natproxy.plus.net.
Might natproxy.plus.net fail to recognise that it is acting as an OBP when it tests whether an OBP is being used?
Detail:
2008-10-05 23:44:43.462 UDP LOCAL->79.135.125.160:5082
REGISTER sip:sip.plus.net SIP/2.0
Via: SIP/2.0/UDP 192.168.0.2;rport;branch=z9hG4bKc0a800020000001048e9435b0ea569cd0000000b
Content-Length: 0
Contact: <sip:6668012@192.168.0.2:5060>
Call-ID: 1A75B9A6-1DD2-11B2-A3B5-CD6F9616910F@192.168.0.2
CSeq: 5 REGISTER
From: <sip:6668012@sip.plus.net>;tag=3475971397586274810
Max-Forwards: 70
To: <sip:6668012@sip.plus.net>
User-Agent: SJphone/1.60.299a/L (SJ Labs)
DEBUG     SIP.Network     0
2008-10-05 23:44:43.509 UDP 79.135.125.160:5082->LOCAL
SIP/2.0 403 Forbidden - no OBP
Via: SIP/2.0/UDP 192.168.0.2;rport=5060;branch=z9hG4bKc0a800020000001048e9435b0ea569cd0000000b;received=84.92.179.154
CSeq: 5 REGISTER
To: <sip:6668012@sip.plus.net>;tag=65c69fd7e8cf96760c930286580e648a.0539
Server: OpenSER (1.2.3-notls (i386/linux))
Content-Length: 0
Roswellgrey
Same here - response to registration attempt using the new proxy is
petergradwell
Sorry about that, Obviously something has been overlooked. I will come back to you.
petergradwell
Quote from: petergradwell
- right, all sorted. Minor technical hitch. Please try again now.
thanks
peter
Roswellgrey
Interesting ....
Reference this -> http://community.plus.net/forum/index.php/topic,67864.msg551466.html#msg551466
using this new proxy seems to have resolved the problem I had  ...
Now, my requested reregister time appears to be honoured.
FYI: The periodic NAT binding refresh results in
12:41:35 SIP.Network DEBUG
2008-10-06 11:41:35.129 UDP LOCAL->79.135.125.160:5082
SIP/2.0 501 Not Implemented
Via: SIP/2.0/UDP 79.135.125.160:5082;branch=0;received=79.135.125.160
To: "#1" <sip:xxxxxxx@sip.gradwell.net>;tag=2621ad2ec4
Call-ID: d0982866-62b60276-ee5102@79.135.125.160
CSeq: 1 OPTIONS
Content-Length: 0
Server: SJphone/1.65.377a (SJ Labs)
teldanet
I have no NAT proxy in my configuration.  I do have my phone going offline quite a bit now and it was working so well.
puddy
I have updated all my internet phones they all show registered but none ring. the person making the call gets a ring tone then it goes to voice mail
Puddy
RichSmol
Peter is dealing with this one directly - i'd suggest that if it doesnt work for you then please revert back to the original nat setting - nat.plus.net. Peter will more than likely know what the problem is without you needing to be connected and actively replicating the problem.
cheers
Rich
RichSmol
works fine for me now!
puddy
Gavin  from gradwell phoned me yesterday and we replicated the fault Its now been fixed.
puddy
fotobits
I have changed to natproxy.plus.net and the only difference I think I have is that my 'phone adapter registers evey 30-mins now (in sympathy with the default 3,600-secs).
Previously it registered every 27-secs, 'though recently it has been registering every 12-secs.
I don't know the reason for, or purpose of these registration changes.
Regards
teldanet
Would someone please tell me what this NAT proxy is for..  It all seems like a conversation for the inner circle and not for the customers.
