Netgear TA612V
Red30
Netgear TA612V
ive got a netgear ta612v and would like to use it with plusnet voip
ive downloaded the unlock firmware from the original vendor (sipgate)
but not sure what info to put in what fields !
if anyone can help it will be much appreciated
1 REPLY
Fixes: 69
Re: Netgear TA612V
What fields do you need info for?
If you can supply a screenshot then I'll do my best to suggest what should go where.
Plusnet Products Team
