Message Waiting Indicator (MWI)
paxy
Is the Message Waiting Indicator functionailty available on the plusnet platform?
Thanks, Paxy
itsme
Re: Message Waiting Indicator (MWI)
Yes, it works on my Flexor 151 and it did on the PAP2. The latter you had to use the web interface to see it. The Flexor has a message waiting light. Unfortunately the 10 minute short ring indicator sent by Gradwell does not work with the DECT phone that I have plugged into the Flexor, the base station has a few seconds thinking time before passing the ringing to the phones.
paxy
ok - enabled voicemail and left a message and the light on my Grabdstream 2020 glows red!  Brilliant!
There is a marker in my settings which was set to No so I am not sure what this does!
"Subscribe for MWI: When set to “Yes” a SUBSCRIBE for Message Waiting Indication will be sent periodically."
I have also set the "Voice Mail UserID:" to *1 so I can get into voicemail at the touch of the envelope button on the phone.
