Logout Disappeared From Broadband Phone Control Panel
As the title says, see screenshot.
Bob
Fixes: 42
Re: Logout Disappeared From Broadband Phone Control Panel
Same here Bob, and if you close the browser window and connect again , it's still logged in!
RobPN
Well spotted!
I couldn't see it hidden under any other section or any other way to logout such as closing the browser window or tab (such as happens with my banking sites).
Edit: Looks like MisterW beat me to it!
Fixes: 8
My VoIP panel menu looks totally different!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 69
Should be sorted now. Shout up if you're still having problems.
Plusnet Products Team
Fixes: 42
yes, we seem to have got a new control panel for a while there, with menus moved about. Bob must have fixed it before you tried.
Yes sorted, thanks.
Bob.
Fixes: 69
The styling in that navigation menu is awful. I've had somebody tidy it up a bit so hopefully it's a little nicer on the eye now?
pnf
The logout option has disappeared again from the VOIP Control Panel.
Fixes: 114
so it has..  also removed a double post pnf (suspect caused by the attachment)
Will Moderate For Thanks
Fixes: 8
As Bob doesn't work weekends, what's the odds this doesn't get fixed until Monday at the earliest?
pnf
Thanks for removing the double post dvorak.  I wondered what had caused that!
Fixes: 69
Taking a look now...
Edit: ref #104683
Petard
Logout has disappeared for me, too. But if I type https://voip.plus.net/login/logout into my browser's address bar, that seems to log me out. (I suppose the script is still there, it's just the menu entry that's missing.) Perhaps subscribers could use this method till the menu's fixed.
Fixes: 69
By the way, I've not forgotten about this folks. Gradwell's second line teams are looking into things. I'll let you know as soon as we've received an update.
