Linksys PAP2T Settings
BestPump
Hi All,
Could anyone please help me with the DEFINITIVE settings for a inksys PAP2T?
I've been fiddling with settings for ages and making a little bit of headway but not getting it up and running.
Everything looks OK on the web based admin of the PAP2 but I have no dial tone and the phone doesn't ring (even though the web-based page sees the incoming call).
Proxy: sip.plus.net
Outbound Proxy: natproxy.plus.net:5082
STUN Enable: Yes
Stun Server: stun.sipgate.net
Many thanks in advance.
Jeff
Fixes: 117
Re: Linksys PAP2T Settings
Sounds like it's not registering, I haven't used a PAP2T but have you tried it without STUN enabled? I don't believe you need it and I haven't got it configured on my equipment.
Will Moderate For Thanks
BestPump
I tried without STUN and the status page didn't register call status, last number etc. but with STUN enabled, it does.
Either way, I get no dial tone and no call abilities. :-(
puddy
Looks like you are trying to use plusnet setting with a few bits of sipgate settings two differant providers
Here you go
UK Settings for Linksys PAP2 Device
Line Enable:  yes
sip port :5060 try 5062 for line 2
proxy :sip.plus.net                  Register: Yes
Make Call Without Reg: No      Register Expires: 3600
Ans Call Without Reg  :  No
Display Name: sip  id number    User ID: sip id number
Password: sip password          Use Auth ID: Yes
Auth ID: sip id number
Audio Configuration
Preferred Codec:G7LLu            Silence Supp Enable: no
Use Pref Codec Only:No          FAX CED Detect Enable:No
DTMF Tx Method: INFO
Line 1  Advance Settings
Proxy and Registration
Outbound Proxy:nat.plus.net:5082 or try natproxy.plus.net:5082
save settings
United Kingdom Regional Settings
Dial tone: 350@-19,440@-22;10(*/0/1+2)
Ring back: 400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
Busy tone: 400@-20;10(.375/.375/1)
Reorder tone: 400@-20;10(*/0/1)
SIT 1 tone: 950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
MWI dial tone: 350@-19,440@-22;10(.75/.75/1+2)
CWT1 cadence: 30(.1/2)
CWT2 cadence: 30(.25/.25,.25/.25,.25/5)
CWT frequency: 400@-10
Ring 1 cadence: 60(.4/.2,.4/2)
Ring 2 cadence (BT Call Sign): 60(1/2)
Ring 3 cadence (BT Ring Back): 60(.25/.25,.25/.25,.25/1.75)
Ring 4 cadence: 60(.4/ .
Ring 5 cadence: 60(2/4)
Time Zone: GMT
FXS Port Impedance: 370+620||310nF
Caller ID Method: ETSI FSK With PR(UK)
Daylight Saving Rule: start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1:0:
UK dial plan
this will change problems when dialing number
( *x. | **x. | 0xxx xxx xxx. | 186 xxx xxxx | [1-8]xx | [1-8]xxx | [1-9]xx xxxx | 00 xxxxx x. | 141 0 x. | 1470 0 x. )
If you get this problem
Applied al lthe settings that were listed by Puddy but couldn't receive incoming calls.
The "Use Outbound Proxy" box  has to be set to Yes
Kind regards
Puddy
beeman
Hi All
I seem to have a somewhat similar problem so I hope you won't mind me tagging it on to the discussion.
I had a VOIP setup with a BT homehub 3 and a PAP2T which worked fine until the ATA became unreliable.
I bought a new PAP2T-NA and transferred all the settings over to the new ATA.
The PAP2T-AN logs on to the router and the router shows it is connected OK. Still can't get a dial tone and the line connected light on the ATA stays off.
Have checked all the settings and also checked them against those recommended by Puddy (Many thanks for that)
Was wondering if anybody has any suggestions I could try before I accept that it must be the PAP2T and send it back.
This is already a replacement for a PAP2T that failed to work so I'm trying to make sure that I have tried everything possible before returning this one as faulty.
Thanks for any suggestions you may have
Best regards
Beeman
