Just checking my settings it been a while.
Hello can I check that all my settings are current for my linksys pap2, I have recently been sorting my voip set up again as it gets more and more use and was just using SJphone up to now on the PC.
These are what I got courtesy of Puddy back in the day.
Line Enable:  yes
sip port :5060 try 5062 for line 2
proxy :sip.plus.net                  Register: Yes
Make Call Without Reg: No      Register Expires: 3600
Ans Call Without Reg  :  No
Display Name: sip  id number    User ID: sip id number
Password: sip password          Use Auth ID: Yes
Auth ID: sip id number
Audio Configuration
Preferred Codec:G7LLu            Silence Supp Enable: no
Use Pref Codec Only:No          FAX CED Detect Enable:No
DTMF Tx Method: INFO
Line 1  Advance Settings
Proxy and Registration
Outbound Proxy:natproxy.plus.net:5082
save settings
United Kingdom Regional Settings
Dial tone: 350@-19,440@-22;10(*/0/1+2)
Ring back: 400@-20,450@-20;*(.4/.2/1+2,.4/2/1+2)
Busy tone: 400@-20;10(.375/.375/1)
Reorder tone: 400@-20;10(*/0/1)
SIT 1 tone: 950@-16,1400@-16,1800@-16;20(.330/0/1,.330/0/2,.330/0/3,0/1/0)
MWI dial tone: 350@-19,440@-22;10(.75/.75/1+2)
CWT1 cadence: 30(.1/2)
CWT2 cadence: 30(.25/.25,.25/.25,.25/5)
CWT frequency: 400@-10
Ring 1 cadence: 60(.4/.2,.4/2)
Ring 2 cadence (BT Call Sign): 60(1/2)
Ring 3 cadence (BT Ring Back): 60(.25/.25,.25/.25,.25/1.75)
Ring 4 cadence: 60(.4/ .Cool
Ring 5 cadence: 60(2/4)
Time Zone: GMT
FXS Port Impedance: 370+620||310nF
Caller ID Method: ETSI FSK With PR(UK)
Daylight Saving Rule: start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1:0:
UK dial plan
this will change problems when dialing number
( *x. | **x. | 0xxx xxx xxx. | 186 xxx xxxx | [1-8]xx | [1-8]xxx | [1-9]xx xxxx | 00 xxxxx x. | 141 0 x. | 1470 0 x. )
Are they still good to go? Only issues I have at the moment is every now and again the phone rings of its own accord for a few second which usually means it reconnecting in some way and the dial tone sounds more like an engaged tone.
Cheers Neil
1 REPLY
Re: Just checking my settings it been a while.
Embarrassed err I think the phone ringing was it telling me there was a message. Deleted the message from my voip account and doesn't seem to be doing it now. The dial tone has changed as well so that was probably telling me the same thing  Smiley
