Issues this morning?
Fixes: 114
Anyone else having issues?
Can't make a call out and voip.plus.net is running very slowly.
Will Moderate For Thanks
Re: Issues this morning?
Incoming calls appear to be fine, however, when you make a call out to PSTN the audio is very very choppy.
Fixes: 114
Managed to make a call out now, but audio is choppy.
James
There's nothing on Gradwell's Service Status page.
I'll get Bob/Chris to try making a call.
James
Replicated at this end.
I'll get CSC to raise an issue with Gradwell.
Fixes: 114
Thanks James
James
Guys - Were you using softwware or hardware phones?
We have an issue currently open with Gradwell and we're supplying additional examples as we see them.
Fixes: 114
Hardware - Granstream BT 100
I have choppy audio on outbound too, SJphone
James
Guys - Gradwell have indicated that one of the servers was not performing correctly, which they have since rebooted and believe this to have resolved the issues that you were experiencing.
They've said that if you're still having problems, to reboot your router and let us know if the problem hasn't gone away.
Fixes: 114
sounding better for me, thanks for the update.
Fixes: 114
Just had a phone call from CSC telling me it's fixed. Good service Smiley
Blue eyed boy
