Is there a problem with VOIP?
tywyn
I tried to use both my VOIP phones this evening but SJ Phone rings and then goes blank and Skype is breaking up. My connection is fine and the reason I wanted to use VOIP was to speak to the bank  as I'm in a queue  for 30-40 mins as they're so busy, I can then listen to a response from the speaker rather than having a phone glued to my ear with the most monotonous music ever created.
I thought that VOIP on PN was the highest priority, so what's the problem?
Fixes: 117
Re: Is there a problem with VOIP?
Mine was fine and then about 4:30 I had one call where we couldn't hear each other and another that was cutting in and out very badly.
I only use it for office hours so haven't tried it since.
Will Moderate For Thanks
RichSmol
tywyn
Thanks for the info, it's working fine again now as I used it for a while last night  Smiley
Fixes: 117
I tried to get on to the gradwell site and I couldn't Smiley
