Incoming calls
naughtymonkey04
Incoming calls
I've just sign up to the VoIP trail and just set up my Gigaset 475ip phone. however, I'm unable to receive incoming calls. I can dial out but, i can't dial in to the 01 number I've  been given.
RichSmol
Re: Incoming calls
do you get a specific error message or BT tone which we can investigate?
Also, please provide me with a list of screenshot of your settings and i'll check everything is ok from that side of things.
cheers
Rich
naughtymonkey04
Re: Incoming calls
Hi Rich
The problem has been  sorted out by Gradwell. There was a mistake with the accounts that where added to the system on 04/04/08. Of which I was one. However, thank you for offer to help.
