Incoming Calls Failing
paxy
When I get a call to my plusnet VOIP phone line the phone rings as expected.
However, as soon as I lift the handset the call terminates and the screen shows missed call.
I have made no changes - my sipgate line is working fine on the same hardware.  (Grandstream 2020).
Help!
zpeterk
Re: Incoming Calls Failing
Mine (Zoom) has been doing that since the recent changes
Hi Paxy,
Did you read the ticket that was sent to you on the 17th April #68469388 just to make sure that you've made any necessary adjustments.
paxy
Yes, read the ticket.  The issue had actually resolved itself, so I have put it down to a Gradwell issue as it only happened on Saturday.
