Inclusive Minutes Reset?
glloyd
When are the inclusive minutes reset, mine have not been reset for several months?
prichardson
Re: Inclusive Minutes Reset?
If you can raise a ticket on your account for this, I can get this looked into for you.
glloyd
Have done ticket 25245639
prichardson
Had a look at this and something doesn't add up too much. The reset it due today anyway, so it has been put on hold to check tomorrow.
Because the reset it due today, it will be a cut and dry situation tomorrow to know if this is functioning.
glloyd
Well here we are with the 5th almost gone and it has still not  been reset. It was SUPPOSED to have been looked at at 9.00am on the 5th but nothing.
paxy
When should the usage reset?  Is it monthly inline with the broadband account?
Robbie
Hi, having a problem with mine too. Have raised a ticket 25207427 but progress seems to be slow - would think it would be easy enough to sort out.....?Huh
pd
My minutes have also not been reset.  Do I raise a ticket?
pd
Robbie
Mine have been reset to 120 today!! Grin
paxy
Mine were not reset...
glloyd
Still waiting for mine to be reset from the 4th.
paxy
They did reset overnight 10th/11th. Expectation was that it should have reset in parallel with my broadband allowance 8th-7th but seems fine now (albeit a little late which will actually be in my benefit!).
I am not sure if the problem has been fixed or if the account was manually reset though...
RichSmol
Its more than likely that your minutes have been reset manually. Your billing date on broadband phone will be the same as your broadband billing date at the point we create your broadband phone account. That means that if you move your Broadband billing date for some reason then they will no longer be in sync. There was a larger problem identified but this has now been fixed so its just a matter of resetting minutes manually prior to your next billing date when it will happen automatically.
cheers
Rich
glloyd
8 days since ticket raised and still not reset Angry
RichSmol
Apologies for the delay - we've experienced an issue with a couple of resets, I've also requested that we have control over the resets through our own admin control pages in the future so we dont have to keep badgering the Gradwell support teams. Phil is onto the rogue cases at the moment so rest assurred that this is in hand.
cheers
Rich
