Inbound calls diverted to voicemail
Annie
Well I made a little more progress. Silly me - I was putting in the default PIN of the GAP phone and not the PIN which I set the base station up with.
I corrected this and thought it was OK. The GAP handset said HS-2 for a few moments. However, I have now lost dial tone on both handsets (note I'm only using this for VOIP so no fixed line attached) but also, when I ring the geographic number, my phone is tied up and I go straight to Plusnet's voicemail system.  don't know how to unengage the VOIP.
Please can someone help.
Annie
Annie
Just an additional note on to the above - strangely, I can dial out but not in.
Annie
Fixes: 117
Is it showing as registered at voip.plus.net?
Will Moderate For Thanks
Annie
Sorry for being a bit slow but where do I look to check this please?
Annie
Fixes: 117
If you sign on here https://voip.plus.net/login/ under account overview what does it say?
Annie
Broadband Phone 120 2009-03-06 12:25:42 01752 ****** ******* (Ext) online until 2009-06-17 12:09:40
Where I have put asterisks, it shows my geographic number and my sip extension.
Annie
Fixes: 117
So that's looking OK.. if you de-register the new handset does the dial tone come back?
Annie
Hi again. No, I have deregistered the additional handset and still no joy. I have even set the original handset back to default settings but this has not helped.
Annie
Fixes: 117
It might not be you, I've just been told all my calls are diverting too.
Fixes: 117
Just tested it and it does.
James
Guys,
I've just done the equivalent of "refreshing" your VoIP service.
Can you try again in 45 minutes and see if your calls are going through?
Annie
Will do. Annie
Annie
Fixes: 117
thanks James, will do.
James
Thanks.
There's only so many times I can listen to Adie's voicemail Wink
Fixes: 44
@Annie,
If that doesnt work, I'd try a reset of the C475. You can do it from the web configurator or by powering off and on. It should retain all the settings ( including handset registrations ) across the reset.
