How do I join the voip trial
teldanet
I successfully use sipgate,  draytel, callcentric, orbtalk on both hard and soft phones.  However plusnet voip has always been a problem.  I have only had it working 100% successfully on express talk softphone.  If I put it on my grandstream 2000 the phone software crashes within 12 hours.  Without plusnet voip, the grandstream works for ever.  I want to be able to use my 240 mins every month without having to turn my pc on every time.  I could at least try to get it to work on my grandstream.
Fixes: 43
Re: How do I join the voip trial
Go to http://trials.plus.net and opt in to the Voip trial. It will take a few days to be activated but I believe you will find it works much better than the standard PlusTalk
puddy
It take it your grandstream is the GXP2000 model?
If so and you run in to problems with the phone I should be able to help you out I run the same phone
puddy
Equipment used and help offered
Grandstream GXP2000
Speedtouch 716v5wl
Siemens 460ip dect
Linksys pap-2
Linksys spa3000 uk spec
