Help to cofigure Sipdroid
Fixes: 15
Just got an Android phone (2.1) and have Sipdroid installed but all I get is "failure to register"
I have
Sip account 1
Username my sip number
password  my sip password
Server natproxy.plus.net
Domain sip.plus.net
port 5060
protocol udp
Fixes: 43
Re: Help to cofigure Sipdroid
Hi HB,
server should be sip.plus.net.
BUT i can't see anywhre you can enter the outbound proxy details ( natproxy.plus.net:5082 )
This http://groups.google.com/group/sipdroid-developers/browse_thread/thread/a5c3d684a303b067 talsk about configuring the underlying mjsip but I'm not sure it explains how...
You might want to try the Android version of 3CX instead http://www.3cx.com/VOIP/voip-phone.html
Fixes: 15
OK remove sipdroid and installed 3cx but all I am getting is waiting for profile. What should the settings be for this?
Fixes: 43
Looking at this config guide http://www.3cx.com/blog/3cxphone/android/configuring/
user - your 7 digit sip id
password - your sip password
external server - sip.plus.net
stun - leave blank ( shouldn't need it with an outbound proxy )
advanced->proxy - natproxy.plus.net:5082
Hope that helps
Fixes: 15
Nope all I get is registering - not registered.
EDIT:-
also tried lon-pbx-12.gradwell.net:5060 as the registrar (as in my router)
Fixes: 43
Is your voip account a non-standard one then ( since you're using lon-pbx-12.gradwell.net:5060 as the registrar in your router ) ?
Whatever you are successfully using in your router ought to work on the phone. I haven't got an Android phone myself but one of my office colleagues has, so maybe I'll get to try my PlusNet account on his phone next week.
Fixes: 69
sipdroid registered fine for me. I entered the outbound proxy details as the stun server under advanced settings.
Was able to make an outbound call but only had one-way audio.
Haven't tried 3cx yet.
Plusnet Products Team
Fixes: 15
Just finished rooting the phone so got to start again  Embarrassed
Fixes: 15
OK having installed a new rom and re-setup 3cx it is all working thanks Mr W.
Fixes: 43
That's good news HB. Saves me messing about with my colleagues phone.
I use 3CX (and it took my some tweaking to get it to work properly) however,  my only moan is really based on the incoming call quality, it's not your usual landline call quality
(like experienced with the generic VoIP software shipped with Nokia N95) it's very digitised. I appreciate that this is down to the codecs used though and probably not much can be done with it..
puddy
Quote from: Hairy
I am glad you got it working!
Would it be possible to put a list of settings you used to get voip to work on your phone here and possably in Plusnet library?
Kind regards
Puddy
Fixes: 15
With the new rom I just used the setting he first provided - which didn't work on the t-mobile stock rom. Werther it was a rooting issue or a rom issue I don't know but it is now connected fine.
