Help setting up fring/plusnet voip on E65
Fixes: 15
Ok so I now have an E65, I have installed fring and got it registered, BUT for the life of me I CANNOT get it to connect to the gradwell platform.
I have skype working so I know the s/w is ok,
So what settings are people using that work please.
puddy
Re: Help setting up fring/plusnet voip on E65
Do you mean setting up the voip via router if so this may help?
Settings for the Nokia E65 below
Profile name  Gradwell
Service profile IETF
Default access point Your router
Public username sip:id number@sip.plus.net
Use compression no
Registration always on or when needed
Use security no
Proxy server
proxy server address  sip:natproxy.plus.net
Realm sip.plus.net
User Name  id number
Password  account password
allow loose routing yes
Transport type UDP
Port 5082
Registrar server
Registrar serv addr sip:sip.plus.net
Realm sip.plus.net
User name id number
Password id password
Transport type UDP
Port 5060
And dont forget this one
tools > settings > phone>  call barring >  internet call barring> anonymous call barring > switch off
Fixes: 43
I THINK the settings you need for Fring are:-
username :  sip ID
password: sip password
proxy:  sip.plus.net
Although I've never used Fring TBH
Have you checked this thread http://community.plus.net/forum/index.php/topic,58951.32.html
itsme
Have you from the voip portal at Account Overview requested Fring? This is needed so that Fring can log on to you Plus Net VoIP account.
Then to setup Fring on your device go to Menu - Settings - Manage Communities. Select Sip then Other, this will then give you
User              Ext No@sip.plus.net
Password     Your Password
Proxy              sip.plus.net
Fixes: 15
yes I did the request and got a sms, I already had fring installed so didn't run it or do I have to?
I will try again tomorrow (I don't get a signal in the house so need to move 1 MILE down the road to get one, which means no internet Angry)
Fixes: 15
Ok got it working with itsme's details, it needed the @sip.plus.net bit
Cheers
