Help !!! Need assistance setting up SIP/VOIP on Nokia E63
DavidButler
I have recently changed my mobile to a Nokia E63 and require help in setting up the SIP /VOIP details.
Proxy server address
Realm
User Name
Port
Regstrar server address & realm
Any help greatly appreciate
James
Re: Help !!! Need assistance setting up SIP/VOIP on Nokia E63
Curteousy of Puddy & Bob
Profile name Plusnet
Service profile: IETF
Default access point: Your router connection Public user name: sip:your ext number@sip.plus.net
Use compression: No
Registration: Always on
Use security No
Proxy server address: sip:natproxy.plus.net
Realm: newsip
User name: your ext number only
Password: your password
Allow loose routing: Yes
Transport type: UDP
Port: 5082
Now press 'Back', select 'Registrar server' and enter the following settings...
Registrar server address: sip:sip.plus.net
Realm: newsip
User name: Extension Number only
Password: Your password
Transport type: UDP
Port: 5060
DavidButler
Excellent
Thanks for your help
