Hardward Phone Keeps Unregistering / Registering
paxy
Hi
I was working fine...Now whilst sitting at my dek I am noticing that my Grandstream 2020 seems to keep unregistering every couple of minutes and then registering again (for those of you who have a 2000 or 2020 you will know that the line goes from bold to normal and then back to bold again in the display).
I have a sipgate line on the same phone and it not exhibiting the same problem.
Anyone with any ideas on what setting I may need to change to stop this happening?
Thanks, Paxy
prichardson
Re: Grandstream 2020 Keeps Unregistering
Do you have unique RTP ports for each server?
I don't have these issues with the 2000, but I do find SipGate wont register any more.
paxy
each account is on it's own port (ie plusnet is on 5060, sipgate 5062 etc...)
Is that what you meant?
prichardson
Exactly what I meant.
Are you using any SIP clients in your local network as well?
paxy
just the 2020 which gets plugged directly into my router....
paxy
I am still experiencing unregistering / registering for a few seconds at a time...
Can anyone in support or anyone who uses a Grandstream offer any suggestings if you have your working?
puddy
Re: Hardward Phone Keeps Unregistering / Registering
Here You go works with my Grandstream GXP2000 so should work with a 2020 hopefully!!!!
  settings I use on my Grandstream GXP2000
Account Name : Plusnet Voip
SIP Server: sip2.plus.net
Outbound Proxy:sip2.plus.net
Sip User ID: account number
Authenticate ID Account number
Authenticate Password account password
Name: name (shows on display)
Use DNS SRV =no
User ID is phone number =no
Sip Reg = yes
Unregister On Reboot =no
Register expiration 3600
Local SIP port: 5060
SIP T1 Timeout:1sec
SIP T2 Interval: 4sec
Sip Transport:=UDP
Use RFC3581 Symmetric Routing =no
Nat Traversal (STUN) =yes
SUBSCRIBE for MWI:=no
PUBLISH for Presence:=no
Proxy-Require : nat.plus.net:5082
SendDTMF: Via RTP (RFC
Early Dial= no
Enable call feature = YES
Session Exp =180
Min-SE =90
Caller req timer =no
Callee req Ref =no
Force timer =no
UAC Spec Ref =omit
UAS Spec Ref =UAC
Force INVITE  =no
Enable 100rel:=no
Account ring tone= you choose
Send Anonymous:= you choose/no
Anonymous Method: =no
Anonymous Call Rej=no
Auto Answer:=NO
Allow Auto Ans byCall:=no
Turn Off Speaker =no
Check SIP User ID: =no
Refer to Use Target:=no
Choice 1:=PCMU
2 TongueCMU
3: G.729A/B
4: G.723.1
5: G.726-32
6: iLBC
7:G.722(wide Band)
8:GSM
SRTP mode:=Disable
eventlist=blank
Special Feature Standard
Let me know how you get on
Regards
Puddy
paxy
Hi Puddy - thanks for that - I will give it a go now...
(interestingly I did raise a ticket and the only thing that plusnet have asked me to change form my original settings was to set Nat Traversal (STUN) =no (I previsouly had it set to yes).
Would it be possible to post the advanced tab as well if you have time?
Mnay thanks, Paxy
paxy
Cheesy
interestingly I had Outbound Proxy set to nat.plus.net:5082 so I have changed it to sip2.plus.net as you suggest.  My only other difference is the NAT Traversal (STUN) which I originally had set to yes (I think that then refers to the STUN server on the advanced tab which I think was probably set to stun.xten.net or something similar).  Plusnet support asked me to set this to no.  All other settings seem to be identical (I have a few more which may be becuase I am on a slightly different phone or newer firmware?)
I will monitor how changing outbound proxy goes but would still appreciate the advanced settings if you get a chance puddy.
Getting the phone to stay online will be such a step forward!
Thanks, Paxy
puddy
                                                           Advance settings as requested
Admin Password:   (purposely not displayed for security protection)
G723 rate: =Yes 6.3 kbps
Silence Suppression := yes
Voice Frames per TX:=2   (up to 10/20/32/64 for G711/G726/G723/other codecs respectively)
Layer 3 QoS: =48  Layer 2 QoS:=0  802.1Q/VLAN Tag =0      802.1p priority value:=0
No Key Entry Timeout: =4   (in seconds, default is 4 seconds)
Use # as Dial Key:= Yes (if set to Yes, "#" will function as the "(Re-)Dial" key)
local RTP port:=5004   (1024-65535, default 5004)
Use random port:=no
keep-alive interval: =20   (in seconds, default 20 seconds)
Use NAT IP=leave blank   (if specified, this will be used in SIP/SDP message)
STUN server:=leave blank   (URI or IP:port)
Firmware Upgrade and
Provisioning:  Upgrade Via      TFTP:=yes      HTTP
         Firmware Server Path:=fm.grandstream.com/g
         Config Server Path: = fm.grandstream.com/g
         Firmware File Prefix:  = blank
         Firmware File Postfix: =blank
         Config File Prefix: =blank
         Config File Postfix: =blank
 Allow DHCP Option 66 to override server:= Yes
 Automatic Upgrade: =Yes, check for upgrade every =60 minutes (default 7 days)
    Always Check for New Firmware :yes
    Check New Firmware only when F/W pre/suffix changes =blank
    Always Skip the Firmware Check:=blank
 Authenticate Conf File: = no (cfg file would be authenticated before acceptance if set to Yes)
Phonebook XML Download: = no  Enable Phonebook XML Download:
 Phonebook XML Server Path:  =blank
 Phonebook Download Interval
: = 0 (0-720)
 Remove Manually-edited entries on Download: =No
Idle Screen XML Download:= no  Enable Idle Screen XML Download:
 Idle Screen XML Server Path:= blank
DTMF Payload Type: = 101
Syslog Server: =blank
Syslog Level: =none
NTP Server:us.pool.ntp.org   (URI or IP address)
 Allow DHCP Option 42 to override NTP server: = no
Distinctive Ring Tone:blank  Custom ring tone 1, used if incoming caller ID is  blank
 Custom ring tone 2, used if incoming caller ID is =blank
 Custom ring tone 3, used if incoming caller ID is  =blank
System Ring Tone: f1=440,f2=480,c=200/400
Call Progress Tones: Dial Tone f1=350,f2=440;
Message Waiting:f1=350,f2=440,c=10/10;
Ring Back Tone:f1=440,f2=480,c=200/400;
Call-Waiting Tone:f1=440,f2=440,c=25/525;
Busy Tone: f1=480,f2=620,c=50/50;
Reorder Tone:f1=480,f2=620,c=25/25;
Syntax: f1=val,f2=val[,c=on1/off1[-on2/off2[-on3/off3]]];
(Frequencies are in Hz and cadence on and off are in 10ms)
Disable Call-Waiting:=no
Disable Call-Waiting Tone:=no
Use Quick IP-call mode:=no
Lock Keypad Update:= no (configuration update via keypad is disabled if set to Yes)
Display Language: English
remove power cable from router for 20 seconds and then try
let me know how you get on?
puddy
ps if you can make sure your router gives the ip phone the same ip address every time on connection
puddy
Quote from: paxy
Cheesy
for the time being use my settings to see if we can solve your problem if not we go back to plusnet
puddy
itsme
The Outbound Proxy has to be nat.plus.net:5082. The Outbound Proxy replace the stun server, hence the reason why the stun server has to be disabled. The function of the Outbound Proxy (and the stun server) is to keep the ports open through the NAT. See Gradwell settings for the GXP2000
puddy
Quote from: itsme
outbound proxy is listed correctly their a setting for that further down see setup page below
Early Dial= no
The setting are on my own grandstream GXP2000 that works with no problem so i am just lending a hand to a fellow plusnet customer
Puddy
itsme
Not sure what proxy this refer to. I have another device which has a Proxy Server which I have use the sip server settings. No wiser after reading the manual for the Grandstream page 33 and page 34.
[quote= Outbound Proxy]IP address or Domain name of Outbound Proxy, Media Gateway, or Session
Border Controller. Used for firewall or NAT penetration in different network
environment. If the system detects symmetric NAT, STUN will not work. ONLY
outbound proxy can provide solution for symmetric NAT.
[quote=Proxy Required]SIP Extension to notify SIP server that the unit is behind the NAT/Firewall.
paxy
ok puddy - thanks for that - great.  A few minor differences again with a couple of extra fields on mine and difference firmware upgrade options but other than that the same!
I am pleased to report that I have not seen the phone go offline this evening whilst I have been at my desk (although I did pop out and cut the grass  Wink )
Interestingly I have looked back at an old screen print of the settings that I had on the old plusnet platform and the outbound proxy was set to sip.plus.net.  I never had the same problem on the old platform so I am so hopeful that the problem is now solved.
Thanks again for your help - I will post again to let you know how it is going and also so anyone else with Grandstream can see the settings we have used to get it working.
hoorah!
paxy
