Hard phone/ata quantity
OLD
Is there any problem haveing say two hard phones or ata's on the same router both set to the same sip account please.
puddy
Re: Hard phone/ata quantity
Nope I have 4 connected at a time and they can be anywhere and they will all ring until one picks up the call.
I had 1 connected at home and my voip mobile (nokia E65/or Nokia N95) connected in spain.  Plus you can make free calls to each phone buy dialing the extension number
I think you can make 3 calls at a time with the same number.
Plus if your mrs is on the voip phone(for hour and hours) and your mate rings you the VOIP phone not in use will ring
puddy
Fixes: 43
I thought it was only 2, Puddy, but I may be wrong. I don't think its actually specified anywhere though...
OLD
Thanks for the infomation gents thats great.
puddy
Nope I have never seen it listed either But I only have  2 ears and half brain and can only deal with one call at a time
My partner says men cannot multi-task anyway  Huh
puddy
