Hacking the voyager 10v
taras
As i have PN voip set up for my e75 im not that bothered but I have a spare voyager 10v now and am wondering how to succesfully register the 10v under the pn servers .. Plus all the settings (pn) in the 10v have gone !!! so I have to start again.
On a side note what would be my voicemail number ?
any help would be wonderful Smiley ty!
Cheesy Cheesy
Fixes: 43
Re: Hacking the voyager 10v
I'm away form home at the moment with limited internet access so it is not easy to help. I have managed in the past to get a Voyager 10V working with the PLusNet voip. You should find this link useful http://www.voipuser.org/forum_topic_5206.html
taras
am currenlty getting this issue!
"Warning: SIP Register is not allowed because TA hasn't gotten IP"
[admin]# sip show reg
Connection Info:
TEL number    :
Expire Time    :  0
Status        :  not ready or no need to Send Registration
Registrar      :  newsip.plus.net:5060
Proxy          :  natproxy.plus.net:5082
Service Domain :  newsip.plus.net
Outbound Proxy :  natproxy.plus.net:5082
Enable        :  No
TEL number    :
Expire Time    :  0
Enable        :  No
[admin]# sip register
[admin]#
taras
update: have got partial success
TEL number     :   *****
Expire Time    :   3600
Status         :   Registration OK
Registrar      :   sip.plus.net:5060
Proxy          :   natproxy.plus.net:5060
Service Domain :   sip.plus.net
Enable         :   Yes
Am getting engaged tone when i can a phone number!
Fixes: 43
Try just newsip as the domain
taras
if I do
sip set domain newsip
I get dns query retry !
tia MisterW Smiley
Fixes: 43
Ok, try the proxy as sip.plus.net.
Failing that i'll check the settings on my 10v when I get home at the weekend.
taras
Nope still getting the "engaged tone"
Fixes: 43
I've have a chance to re-look over the thread.
It looks like your 10V is registering properly.
A few things to check...
Does it show 'online' if you login to your account on voip.plus.net ?
Have you tried your account using a softphone such as x-lite ?
Do you have any credit on your account, even if you have any included minutes you can't make outgoing calls
unless your account is in credit.
Finally , are you sure its the 'engaged' tone, the tones on voip are quite often somewhat different
to those on a normal landline. Do incoming calls work ?
Hope that helps.
taras
Quote from: MisterW
Status natproxy, expires at 2010-10-07 22:17:01, logged into v-sip-1
NAT: 66 on v-nat-proxy-1 from 80. internal IP 192.168.1.72, until 2010-10-07 21:47:23
NAT: 66 on v-nat-proxy-1 from 80. internal IP 192.168.1.72, until 2010-10-07 21:47:05
NAT: 66 on v-nat-proxy-1 from 80. internal IP 192.168.1.72, until 2010-10-07 22:17:02
SIP Device VOYAGER10V/2.16
SIP Server sip2.plus.net:5060
My nokia e75 wasn't on that list as didn't re-reg to voip when I came back into the house
works with a nokia e75
yes at 0.03 was reload to .50 by pn staff (not made any calls that would warrent it to go down
its exactly like an engaged tone after you have dialed a number :|
Hope that helps.
Thanks Smiley
Fixes: 43
Hi taras,
Sorry about the delay in replying but I've only just had chance to get out my 10V and try it...
These are my settings
TEL number    :  ******
Expire Time    :  3600
Proxy          :  sip.plus.net:5060
Enable        :  Yes
I have my 10V set to 'Bridge mode' and to get an IP via DHCP but that shouldn't be significant as far as sip is concerned.
One thing you could try is to set the sip packet trace using 'sip set pktdump 1' That should then dump out all the sip packets to the telnet window and will show us whats happening when you try and make a call. Either post the output here ( with any public ip's / usernames removed ) or drop me a PM with the output and I'll look to see what's going on.
taras
[admin]# OPTIONS sip:*@192.168.1.72:5060 SIP/2.0
Via: SIP/2.0/UDP 79.135.125.160:5082;branch=0
To: sip:*@sip.gradwell.net
Call-ID: 4f1589a5-76c31dd1-c75d@79.135.125.160
CSeq: 1 OPTIONS
Content-Length: 0
p:*@192.168.1.72:5060;user=phone>
Allow: ACK, BYE, CANCEL, INVITE, REFER, OPTIONS, INFO, MESSAGE, REGISTER, NOTIFY
Supported: timer
Accept: application/sdp
Content-Type: application/sdp
Content-Length: 116
v=0
o=SIP-Gateway-0001 0 0 IN IP4 192.168.1.72
s=RTP Audio
c=IN IP4 192.168.1.72
t=0 0
m=audio 0 RTP/AVP
a=
Call-ID: 4f1589a5-05951dd1-695d@79.135.125.160
CSeq: 1 OPTIONS
Content-Length: 0
Supported: timer
Content-Length: 116
v=0
s=RTP Audio
t=0 0
m=audio 0 RTP/AVP
a=
settings are as
TEL number     :  66
Expire Time    :   3600
Enable         :   Yes
Am totally stummped as my nokia e75 is making calls out Smiley
Fixes: 43
There's nothing in that pktdump to indicate an attempt by the 10v to initiate a call. Is that all the log ? that looks like just the idle packets, there should be more than that when you try and make a call.
Fixes: 43
Did you ever get any further with the 10v ?
