Granstream GXP2000/2020 settings
puddy
Settings For  Grandstream GXP2000/2020
For Paxy Wink
Account Name : Plusnet Voip
SIP Server: sip.plus.net
Outbound Proxy:natproxy.plus.net:5082
Sip User ID: extension number
Authenticate ID extension number
Authenticate Password voip account password
Name: name (shows on display)
Use DNS SRV =no
User ID is phone number =no
Sip Reg = yes
Unregister On Reboot =no
Register expiration 3600
Local SIP port: 5060
SIP T1 Timeout:1sec
SIP T2 Interval: 4sec
Sip Transport:=UDP
Use RFC3581 Symmetric Routing =no
Nat Traversal (STUN) =no
SUBSCRIBE for MWI:=no
PUBLISH for Presence:=no
Proxy-Require : natproxy.plus.net:5082
SendDTMF: Via RTP (RFC
Early Dial= no
Enable call feature = YES
Session Exp =180
Min-SE =90
Caller req timer =no
Callee req Ref =no
Force timer =no
UAC Spec Ref =omit
UAS Spec Ref =UAC
Force INVITE  =no
Enable 100rel:=no
Account ring tone= you choose
Send Anonymous:= you choose/no
Anonymous Method: =no
Anonymous Call Rej=no
Auto Answer:=NO
Allow Auto Ans byCall:=no
Turn Off Speaker =no
Check SIP User ID: =no
Refer to Use Target:=no
Choice 1:=PCMU
2 TongueCMU
3: G.729A/B
4: G.723.1
5: G.726-32
6: iLBC
7:G.722(wide Band)
8:GSM
SRTP mode:=Disable
eventlist=blank
Special Feature Standard
puddy
paxy
Re: Granstream GXP2000/2020 settings
Hi Puddy
These settings work a treat - thanks for your support, it is much appreciated.
Regards, Paxy
paxy
HI Puddy - No problems all week with the phone - all still fine!
Thanks Again!
Paxy
puddy
Great News
Glad I could help
puddy
