Grandstream VOIP Phone query
ruthwhiteyoga
Can someone tell me if the Grandstream BudgeTone 200/201 simply plugs into the router and then works??
At my wits end with the Plusnet voip system not working at all using a Linksys IPA and BT phone/headset combo.
Will the Grandstream Voip Phone stop the line going dead evertime we pick up an incoming call.
Many thanks Smiley
puddy
Re: Grandstream VOIP Phone query
Hi
It will plug in to your router but need a small amount of info about your plusnet voip number password it quite simple.
Try searching in this forum for setting up a grandstream GXP2000 it will guide you through the setup.
But we will try and help you if you get stuck
If your buying a grandstream budget tone 200 dont pay over £34 for a brand new one of e-bay
Puddy
paxy
I am running a Grandstream 2020 and have had very little problems for the last year or so - like puddy I am happy to help if you need me...
