Gigaset - is it a C450 or C460?
AndrewMBaines
When I connect to my phone via a browser, the page is titled C450IP, but written on the black box is C460IP. Is this correct?
puddy
Re: Gigaset - is it a C450 or C460?
updated 7/10/08
Here you go for your settings
go in to settings
ip Configuration
ip address type =obtained automatically
remote management
allow access from other networks = no
Telephony settings
connections then edit
Authentication = sip id/user name
Authentication Password = passoword
Confirm authentication password= password
Username= sip id/username
Domain=sip.plus.net
Display Name = your name
Proxy server address=sip.plus.net
Proxy server port=5060
Registrar server= sip.plus.net
Registrar server port=5060
Network
STUN enabled=no
STUN server= leave blank
STUN port=3478
NAT refresh time=20 sec
Outbound proxy mode=always
Outbound proxy=natproxy.plus.net
Outbound proxy port=5082
Voice codecs
Voip volume= high
Enable Annex B for G729=no
selected codecs
remove G726
Click set
It may show as unregistered but leave for 10 mins when it will show registered
Dialing Plans
just set to no
Advanced Settings
DTMF over VoIP Connections
send settings tick in ref2833 and sip info
Hook Flash
application type=dtmf-relay
application signal=20
Listen Ports for VoIP Connections
sip port=5060
RTP port =5004
Use random ports =no
Click set
Miscellaneous
already setup
Puddy
AndrewMBaines
Thanks the only difference I had was in the proxy server address, but if you're getting the 10 second delay too......
