Gigaset N300ip Registration failed
scotland731
I am close to putting my Gigaset N300IP in the bin. I have followed posts on this forum and despite entering the correct details it fails to register.
I have included a screenshot and have had Plusnet confirm password although they only reset it, I have done this in the control panel.
I have the Gigaset.net registered ok.
In the control center it sees the nat information and the IP address of my Gigaset.
Fixes: 44
Re: Gigaset N300ip Registration failed
Hi, Are you expecting the N300 status display to update automatically when it registers ? it doesn't. You need to manually refresh it for it to show registered. The fact that the control panel shows the NAT information and IP tends to indicate that it's actually registered. Does it show something like this ?
nat.thw, expires at 2014-05-14 09:11:06, logged into v-sip-1
NAT: 8xxxxxx on from 80.229.nnn.nnn (80-229-nnn-nnn.plus.com), internal IP 192.168.5.70, until 2014-05-14 09:11:09
What happens when you try to make/recieve a call ?
Fixes: 4
Quote from: MisterW
That is true (or it often takes a couple of minutes to update the displayed status) - that used to confuse me,  Embarrassed
HOWEVER the display on the wireless handset(s) WILL change from not registered, to normal, fairly instantly.  Wink
Fixes: 44
I couldn't remember whether the handset showed the status all the time... Mine are all set to blank the display when not in use
Fixes: 4
When the wireless handset is sitting in its charging cradle, mine are set to display the digital clock, but when the VoIP connection fails then the display changes to indicate that registration has been lost.
scotland731
Thanks for your replies.
Both handsets report the same that registration has failed.
I don't think I have missed anything, I can log into the voip control panel and change the password.
I haven't tried to make a call on the voip but expected the unit to show that it has registered, I have refreshed and this was after 16 hours.
I have pstn connected too and can use that.
I have a linksys x3500 router and have opened the ports to try and rule out the firewall.
I guess I need to try the connection lol.
Fixes: 117
have you got a smartphone that you can test using a sip client ?
Will Moderate For Thanks
Fixes: 44
There used to be some issues with sip id's that started with a '4', not sure if it's still a problem. http://community.plus.net/forum/index.php/topic,115701.32.html
You had to drop the leading digit...
scotland731
A big thank you MisterW you solved my problem and explained another why on the confirmation email my extension\account number had the 4 in, but the answer in the member centre didn't.
Also thankyou to those who contibuted.  Cool
Fixes: 117
He's not a bright spark for nothing Cheesy
Glad it's sorted for you Smiley
Fixes: 44
TBH I was clutching at straws there Smiley I really thought that problem had been fixed, obviously not Roll eyes
